Sending an ASCII 0 to the BSII
Hello,
I am trying to get the serial protocol to work in order to send a
bsii program to a bsii. When I send an ascii 0 (Null), I get back a
chr$(48) which is "0" instead. I am using VB 5.0. Can anyone please
help. I have tried eveything such as Chr$(0).
Curtis
Curtis
Things you've implied:
1. You are trying to utilize the BS2 download protocol,
to send a pre-compiled BS2 program from a PC to the
BS2, using Visual Basic 5 on the PC.
2. I assume you're using the VB5 'Comm' control.
I've used the VB6 'Comm' control, which works better.
It sounds like most of your problems exist on the VB
side, not the BS2 side, is that correct?
3. It is not clear what platform and language you
are using to "send an ascii 0 (null)", and what
platform and language you sent it to, that is
reporting "I get back a CHR$(48)". The BS2 has
very clever formatting in its SERIN statements.
It's not clear what you are using.
Please reply with more detail. I'm sure this
is a solvable problem.
--- In basicstamps@yahoogroups.com, "cenlasoft" <cenlasoft@y...>
wrote:
> Hello,
a
please
> Thanks,
> Curtis
> Wow, that's confusing.
> protocol,
> YES
> better.
> VB
> IT SEEMS VB IS THE PROBLEM
> I SIMPLY USE MSCOMM1.OUTPUT = CHR$(0)
> EVERYTHING WORKS TO THAT POINT WHERE I SEND AN ASCII
0 OR NULL REGARDLESS OF WHAT 0 OR NULL I GET BACK A
CHR$(48) OR "0".
THANKS FOR YOR HELP.
CURTIS
> <cenlasoft@y...>
> wrote:
> > Hello,
> order to send a
> (Null), I get back
> a
> Can anyone
> please
> > Thanks,
> > Curtis
> from the same email address that you subscribed.
> Text in the Subject and Body of the message will be
> ignored.
__________________________________
Do you Yahoo!?
The New Yahoo! Search - Faster. Easier. Bingo.
http://search.yahoo.com
a BS2 from a PC using Visual Basic, and you can't
seem to send an actual '0' (Always gets sent as
character "0".)
I've reviewed my code, and the only thing I can
see that VB might need is:
dim BufStr as String
BufStr = CHR(0)
MSComm1.Output = BufStr
' I think 'Output' HAS to be given a String, or a
' Byte array.
' Note also the BS2 is going to echo back EVERYTHING
' that gets sent to it.
' Note if you're looking at the value at the BS2,
' you need:
MyBytes VAR BYTE[noparse][[/noparse]4]
SERIN MyBin, MyBaud, [noparse][[/noparse]MyBytes\4] ' Don't use 'STR' modifier
** Note you can quickly convert ByteArray to string in VB by:
Sub BytesToString(InBytes() As Byte, OutString As String)
' Given a ByteArray, gives you the equivalent VB
' native Unicode String.
OutString = StrConv(InBytes, vbUnicode)
End Sub
And the other way:
Sub StringToBytes(InString As String, OutBytes() As Byte)
' "VB lets you force Unicode conversion by using the StrConv
' function." Hardcore VB5, Page 85.
' The result is a byte array equivalent of the VB5 native
' Unicode String type, converted to ASCII.
' Note this was put here to document this obscure use of
' the 'StrConv' function. In practice, you can cut and
' paste the following line into your code, if you want to
' remove the overhead of a function call.
' AcL 3/7/2002
OutBytes = StrConv(InString, vbFromUnicode)
End Sub
> Earlier: Sending data from a PC to a BS2
