Using extra memory on BS2-SX (
Archiver
I just got my BS2-SX. Until now, I've been using a (original) BS2. My
program compiles on a (original) BS2 just fine. I put it on the BS2-
SX, and it needed some tweaking on serial port timers, and on timeout
values.
My problem is that on the BS2-SX, when I split it across
multiple "pages", it has a problem. It will not compile into tokens.
I get an error saying that any label not in the current "page" is
an "undefined label".
Here are the specifics of what I'm doing:
I have 4 files: "A-Robot1.bsx", "A-Robot2.bsx", "A-Robot3.bsx" and "A-
Robot4.bsx" If I open "A-Robot1.bsx" in the Parallax editor, then all
4 come up. The lables on the tabs at the top of the screen read "0:A-
Robot1.bsx", "1:A-Robot2.bsx", "2:A-Robot3.bsx" and "3:A-Robot4.bsx"
I've changed my directive in my first file ("A-Robot1.bsx") from the
default for a BS2-SX (obtained by clicking on the blue stamp)
to: "'{$STAMP BS2sx, A-Robot2.bsx, A-Robot3.bsx, A-Robot4.bsx}". I
have no directive on any of the other 3 files. ("A-Robot2.bsx", "A-
Robot3.bsx" and "A-Robot4.bsx")
The line that gives me an error is: "gosub rcServo". Before I cut-and-
pasted my program into 4 windows, it worked perfectly, with the BS2-
SX.
What am I doing wrong? Can I even make a call from one program window
to another? If I can not, the BS2-SX's extra memory is useless.
Andy@A...
values.
SX.
Andy@A...
2K bytes at a time. So, the SX handles the additional
memory by bank-switching.
What this means to you: You can 'run' the other
2K partitions, but you can't "call" into them.
Well, there are ways to do something which has the
same effect. You'll have to look at the Parallax
documentation to get the technique.
But it's not very simple.
--- In basicstamps@yahoogroups.com, "recycledelectro" <Yahoo@R...>
My
timeout
> values.
tokens.
and "A-
all
read "0:A-
the
and-
> SX.
window
> Andy@A...
over to a BS2SX. This has absolutely nothing to do with the code segments as
the BS2 has none. If it fits on a BS2, it will fit in one code segment of a
BS2SX. There may be some tweaking involved on a few statements, but the code
should run.
Adding code and switching to the other code segments is entirely different.
It would be foolish to attempt this until you get the original code working
again. It does not make sense to throw in other issues until you take care
of the first one.
What the others have said are true -- each code segment is a separate deal,
and when you jump to a new segment you start at the beginning (top) of the
code. There are methods for passing things back and forth and jumping to
certain places in the code. Someone probably has those messages archived and
can direct you to them.
Sent: Wednesday, May 21, 2003 11:48 PM
Subject: [noparse][[/noparse]basicstamps] Re: Using extra memory on BS2-SX ("undefined label"
error)
> So sorry, the BS2 technology only really handles
> My
> timeout
> > values.
> tokens.
> and "A-
> all
> read "0:A-
> the
> and-
> > SX.
> window
> > Andy@A...
programming for the BS2e, BS2sx, or BS2p a while back
that should get you up and running. link for download
below:
http://www.parallax.com/Downloads/Documentation/nv/v3/col/NV87-Multi_Bank_Progra\
mming.pdf
ross
--- recycledelectro <Yahoo@R...>
> (original) BS2. My
> put it on the BS2-
> values.
> across
> current "page" is
> editor, then all
> screen read "0:A-
> "3:A-Robot4.bsx"
> blue stamp)
> A-Robot4.bsx}". I
> Before I cut-and-
> SX.
> one program window
> is useless.
> Andy@A...
> Text in the Subject and Body of the message will be
> ignored.
__________________________________
Do you Yahoo!?
The New Yahoo! Search - Faster. Easier. Bingo.
http://search.yahoo.com
I have some information posted too about cross-bank "calls" at this URL:
http://www.emesystems.com/BS2SX.htm
BASICally, you have to create your own return stack and RUN the other
bank with an index pointer to a routine there. The return stack
contains an index pointer to the place you need to return to in the
calling bank. The variables have to be defined the same way in each
bank. It is a bit complicated, and you will have a much better time
with it if you organize the program in a "paged" manner to begin
with. You will inevitably end up with copies of commonly used snall
routines in each bank that uses them.
In my opinion, the BS2p and the BS2pe are vastly superior for most
purposes for cross bank programming. You can access data via READ
and WRITE in any bank without actually having to RUN the other bank.
-- Tracy
>values.
>SX.
>Andy@A...
--- In basicstamps@yahoogroups.com, "Rodent" <daweasel@s...> wrote:
> We have two issues here he needs to deal with. One is porting the
BS2 code
segments as
segment of a
the code
> should run.
True! I did that, by changing 4 constants (timeouts for various
serial ports.) The reason I went to a BS2-SX was to get more code
space. I was at 97% and holding, so I got a Stamp with a bigger
memory. I had redesigned my program to fit in 4 banks, and ***-U-ME-D
that I could make calls across banks. Oooops. It was time to learn
the BS2-S's screwed up memory system, and then to redesign.
different.
working
take care
> of the first one.
My code worked just fine on the BS2-SX in a single bank, my question
was about splitting it into multiple banks. I thought I said that
(see below) but I'll try to be more clear next time.
BS2.
> > My
BS2-
> > timeout
> > > values.
> > tokens.
is
cut-
> > and-
BS2-
> > > SX.
