pin assignment — Parallax Forums
pin assignment
edited 2003-05-21 16:43 in General Discussion
Pretty much a newbie. Working on a project where I am learning from
pouring over the code of someone's project that is pretty similar.
He defines his pins using the CON constants. No problem there. But
he does this:
'* BS2 Pin Definitions *
' con 0 '
TNC_Out con 1 'data to TNC
TNC_In con 2 'data from TNC
GPS_In con 3 'data from GPS
GPS_Out con 4 'data to GPS
RH con 5 'data from relative humidity
Servo con 6 'data to servo controller
Stretch con 7 'data to stretcher
' con 10 '
GM con 11 'count from GM
CLK con 14 'clock line
DATA_IO con 15 'data line
RS232_Port con 16 'RS232 line
Here he is defining the pins as in p0-p15, correct? But he has a pin
16. How is that?
Like I say... I am a newbie. Thanks.
    edited 2003-05-21 15:50
    Pin 16 is the serial port you talk to the PC with during programming and
    with debug windows.
    > he does this:
    > 16. How is that?
    edited 2003-05-21 15:54
    In a message dated 5/21/2003 10:52:19 AM Eastern Daylight Time,
    kingfm@y... writes:
    > 16. How is that?
    Pin 16 should not be defined. This is the hardware pin for debugging or
    serin/serouting to the debug screen.
    Sid
    He is most likely defining that in order to use it for serial communications
    to a PC or what ever serial device the program maybe running. Even though
    it's the pin used for programming the stamp allows you to use it as well...
    but you can only use it for RS232 serial communications.
    I'd recommend you check out the stamp manual page 273 and 293 (or according
    to acrobat page 275 and 295) read the TPin and FPin parts of the serin and
    serout sections.
    http://www.parallax.com/Downloads/Documentation/bs/BASIC_Stamp_Manual_v2-0.p
    df
    If you specify pin 16 in either serin or serout the stamp will use it's
    dedicated serial pins (physical pin 1 and 2).
    Chris Shuster
    Sent: Wednesday, May 21, 2003 10:49 PM
    Subject: [noparse][[/noparse]basicstamps] pin assignment
    > he does this:
    > ' con 0 '
    > ' con 10 '
    > 16. How is that?
