Why is BS so gay? — Parallax Forums
Why is BS so gay?
edited 2003-05-22 22:22 in General Discussion
What ??
Sent: Wednesday, May 21, 2003 7:55 PM
Subject: [noparse][[/noparse]basicstamps] Why is BS so gay?
> 0=on and 1=off, sometimes. wtf?
    edited 2003-05-21 12:55
    edited 2003-05-21 13:10
    ...and why are dogs lips black?
    > Depends on whether the pin is pulled high or low to switch.
    > At least I'm guessing that's what you were asking?!?
    edited 2003-05-21 13:12
    From: dcalotta [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ZE6AcKzJvog9uTNyQ6Vk8vL6URt5ic2Qfb8y7k22yKttwl03pOJPs8DBQNAiQ60gD1uGlRGyvO6YJg]dave@c...[/url
    Sent: 21 May 2003 12:55
    edited 2003-05-21 13:38
    Assuming you have an LED, for example, wired up to turn on when low --
    and this offends you so strongly -- you could write something like this:
    ON con 0
    OFF con 1
    LED var pin9
    LED=OFF
    Of course, you might have cases where you have somethings that turn on
    with a 1 and some with a 0, in which case you might like to write:
    ON con 1
    nON con 0
    OFF con 0
    nOFF con 1
    nLED var pin9 ' inverted LED
    LED var pin8 ' positive LED
    nLED=nON
    LED=ON
    Etc.
    Al Williams
    AWC
    * Free standard shipping this week only
    http://www.al-williams.com/awce
    > From: dcalotta [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=WBflhr1lWeeK8_ypzo9pmL4Y9nxZ6tqqWV-SsTxOJDB03Bxj0swFUtMv89cMr9vFRfAp8oWkvge9]dave@c...[/url
    > Sent: Wednesday, May 21, 2003 6:55 AM
    edited 2003-05-21 14:18
    As Al points out, we often wire LEDs to turn on when with a low signal. This
    habit, I believe, developed because many devices can sink more current than
    they can source.
    One note on the example code below: ON is a keyword in PBASIC 2.5 and will
    cause a compiler conflict. I have modified my programs like this:
    IsOn CON 0
    IsOff CON 1
    -- Jon Williams
    -- Parallax
    In a message dated 5/21/2003 7:41:59 AM Central Standard Time,
    alw@a... writes:
    > ON con 0
    > OFF con 1
    > LED var pin9
    > LED=OFF
    > ON con 1
    > nON con 0
    > OFF con 0
    > nOFF con 1
    > nLED=nON
    > LED=ON
    > Etc.
    > Al Williams
    > AWC
    > >From: dcalotta [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=BBKhBtpTrER69wTmMxujr6JnmOtyZBr_O88qQBNQaRygFyTQfe83y7wXphaAsajuaQU-_7Nb__-A]dave@c...[/url
    edited 2003-05-21 14:28
    Whoops, of course Jon is correct. Perhaps nOn, nOff (for inverted) and
    tOn, tOff (for non-inverted). I guess I will have to start looking at
    2.5 :-)
    Al Williams
    AWC
    > From: jonwms@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=-uwLj_uxqNFarNZHZyE50_SL_igRo1AtWS9fLSHefspb-T6z6uBcxBJi92Fc-_a2JsSLbkI9pWvt]jonwms@a...[/url
    > Sent: Wednesday, May 21, 2003 8:18 AM
    > Subject: Re: [noparse][[/noparse]basicstamps] Why is BS so gay?
    > low signal. This
    > more current than
    > they can source.
    > 2.5 and will
    > IsOn CON 0
    > IsOff CON 1
    > -- Jon Williams
    > -- Parallax
    > alw@a... writes:
    > when low --
    > > this:
    > > ON con 0
    > > OFF con 1
    > > LED var pin9
    > > LED=OFF
    > that turn on
    > > ON con 1
    > > nON con 0
    > > OFF con 0
    > > nOFF con 1
    > > nLED=nON
    > > LED=ON
    > > Etc.
    > > Al Williams
    > > AWC
    > > >From: dcalotta [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=FFd2vzglKHZFOm00zifMVBobVUndNGOTbiRjzLhqT-RochAhAqwDKK1Rt1h9QzVA-rrz-a_d7TD_RQE]dave@c...[/url
    edited 2003-05-21 17:42
    This happens because of the difference between
    voltage and current, and as other posts have
    mentioned -- chips tend to be able to sink (take
    in) more current than they can source (put out).
    If you have an LED with one end tied to +5,
    a 470 ohm current limiting resistor, and
    then the Stamp pin, then you will turn
    ON the LED with a LOW on the stamp. Thus
    a 0 voltage selected leads to current flow
    'on'.
    In code comments, I tend to call this
    'active low logic', where 0 results in
    an ON state in some device.
    If the LED was tied to Ground, then you'd
    have 'active high logic', and a high on
    the BS2 pin WOULD drive the LED 'on'. Note
    that the BS2 is rare in that it can do this,
    most processors can't source as much current
    as the BS2 module can.
    So that's why it's sometimes "Low == ON", and
    other times "High == ON".
    edited 2003-05-22 19:29
    If electron flow is from negative to positive, are you not sourcing
    current when a negative is provided; sinking current when a positive is
    provided???
    > they can source.
    > IsOn CON 0
    > IsOff CON 1
    > -- Jon Williams
    > -- Parallax
    > alw@a... writes:
    > > ON con 0
    > > OFF con 1
    > > LED var pin9
    > > LED=OFF
    > > ON con 1
    > > nON con 0
    > > OFF con 0
    > > nOFF con 1
    > > nLED=nON
    > > LED=ON
    > > Etc.
    > > Al Williams
    > > AWC
    > > >From: dcalotta [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=_UtAqRFpaIOF8PM4P5lkNCLc-DAFKnXixuClm7PXSeqnX9pzavdT4nSmypKVD6ya1x8Ux3PR3X9Wfw]dave@c...[/url
    edited 2003-05-22 22:06
    Aha, electron flow...
    Yes, electron flow IS from negative to positive, but
    back when they were discovering electricity, they
    didn't know that. So they defined 'Charges' and
    'Current Flow' from positive to negative. Positive
    current flows from the positive terminal of a
    voltage source to the negative terminal. That
    is the convention, and how it is defined.
    In TTL circuitry, they defined +5 volts as the
    standard positive voltage, and 0 volts as
    'ground'. I suppose what really happens is
    that electrons come creeping up out of 'ground'
    under the stimulus of the voltage differential
    between ground and +5, and so you get a
    negative current flow of negative charges, which
    results in a positive current flow the other
    way. While you can think this way if you want,
    there's a lot of literature written assuming you
    (and everyone else) thinks the other way. You
    are adding an enormous confusion factor.
    So, when one end of the LED is tied to +5, and
    through a current limiting resistor the other
    end is tied to the Stamp, and the Stamp then
    outputs a '0', what is said to happen is that
    the Stamp 'sinks' the (by convention positive)
    (consisting of "positive charges")current
    from the +5V power supply through the
    LED, and it lights (turns 'on').
    The Stamp is really 'sourcing' electrons in this
    case, which are being 'sucked' by the +5V
    power terminal -- in which case the Stamp is
    'sourcing' negative current. It's the same
    thing as saying the Stamp is 'sinking' positive
    current -- which is the standard way of saying it.
    --- In basicstamps@yahoogroups.com, Don Denhardt <dondenhardt@y...>
    positive is
    > provided???
    signal. This
    current than
    > > they can source.
    and will
    > > IsOn CON 0
    > > IsOff CON 1
    > > -- Jon Williams
    > > -- Parallax
    > > alw@a... writes:
    low --
    like this:
    > > > ON con 0
    > > > OFF con 1
    > > > LED var pin9
    > > > LED=OFF
    turn on
    write:
    > > > ON con 1
    > > > nON con 0
    > > > OFF con 0
    > > > nOFF con 1
    > > > nLED=nON
    > > > LED=ON
    > > > Etc.
    > > > Al Williams
    > > > AWC
    > > > >From: dcalotta [noparse][[/noparse]mailto:dave@c...]
    If memory serves me right, in much the same way the Earth's magnetic poles
    are reversed from actuality. Historically the north "seeking" pole of a
    magnet was named because it was attracted toward the Earth's North Pole,
    which is in actuality polarized as the south pole.
    No wonder I get lost all the time!!!
    Yiipes....
    Mike Sokol
    Sent: Thursday, May 22, 2003 5:06 PM
    Subject: [noparse][[/noparse]basicstamps] Re: Why is BS so gay?
    > positive is
    > > provided???
    > signal. This
    > current than
    > > > they can source.
    > and will
    > > > IsOn CON 0
    > > > IsOff CON 1
    > > > -- Jon Williams
    > > > -- Parallax
    > > > alw@a... writes:
    > low --
    > like this:
    > > > > ON con 0
    > > > > OFF con 1
    > > > > LED var pin9
    > > > > LED=OFF
    > turn on
    > write:
    > > > > ON con 1
    > > > > nON con 0
    > > > > OFF con 0
    > > > > nOFF con 1
    > > > > nLED=nON
    > > > > LED=ON
    > > > > Etc.
    > > > > Al Williams
    > > > > AWC
