apply the
Is that possible to stop and hold
torque from a servo using "HIGH"
or other command?
Because the "pulsout" could stop the
servo but without torque.
Thanks: Joe
__________________________________
Do you Yahoo!?
The New Yahoo! Search - Faster. Easier. Bingo.
http://search.yahoo.com
or other command?
Thanks: Joe
Do you Yahoo!?
modified for continuous rotation. If you output the center pulse
(usually 1.5mS) the servo should "resist" changes. If you don't output
any pulse, the shaft will be free to turn.
Or do I not understand what you are asking?
Al Williams
AWC
* Free standard shipping this week on all orders
http://www.al-williams.com/awce
> From: Joe Terk [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=lIlGV706w2EJ7wdcSI_Fhv2feMMnmFNEHBPHm2yRHQ28PFLChpqkrAsQgJnWbyvtcH-q11_Nits]joeterk@y...[/url
> Sent: Tuesday, May 20, 2003 4:03 PM
> Subject: [noparse][[/noparse]basicstamps] apply the "HIGH" command to stop a servo.
> Hi,
> or other command?
> Thanks: Joe
> Do you Yahoo!?
> The New Yahoo! Search - Faster. Easier. Bingo. http://search.yahoo.com
> from the same email address that you subscribed. Text in the
But I forgot to writte that my idea is to
stop a servo (continous or not) but holding
the torque.
Because if I use 1.5mS the servo stops
but without holding torque.
Thanks: Joe
--- Al Williams <alw@a...> wrote:
> If I understand you correctly, you are probably
> talking about a servo
> center pulse
> If you don't output
> Al Williams
> AWC
> > From: Joe Terk [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=hSdHJNRfi_REh_84v89ZVfnqK95KVuAKdzX8jZDfF2Oe_YqTWbcxKywg3FoboyaFDpfV0tqTgn95]joeterk@y...[/url
> stop a servo.
> > Hi,
> > or other command?
> > Thanks: Joe
> > Do you Yahoo!?
> Text in the
> Text in the Subject and Body of the message will be
> ignored.
Do you Yahoo!?
in an infinite loop. Won't that hold the 'torque'?
--- In basicstamps@yahoogroups.com, Joe Terk <joeterk@y...> wrote:
> Thanks Al:
> the torque.
> Thanks: Joe
> > center pulse
> > If you don't output
> > Al Williams
> > AWC
> > > From: Joe Terk [noparse][[/noparse]mailto:joeterk@y...]
> > stop a servo.
> > > Hi,
> > > or other command?
> > > Thanks: Joe
> > > Do you Yahoo!?
> > Text in the
> > ignored.
> Do you Yahoo!?
