tooling telescoping tube
I wonder if you guys who make robots and mechanical things might have
any advice about this.
I have a 2 inch long stainless steel tube, 5/8" o.d., 0.029" wall,
and I need to cut a longitudinal slot in the wall. The slot has to
be between 0.08" and 0.1" wide, and it has to be 0.6" long, starting
0.25" from one end of the tube.
I don't know what tooling would work best to cut a clean slot. side
cutter? grinder? rotary tool? I have a lathe and a die grinder.
The idea is that this tube will telescope into another tube, and a
#52 machine screw will come through the outside tube into the slot
and constrain the travel. There will be a detector switch at the end
inside the slot that will be activated by the screw coming in from
outside.
-- best regards
Tracy Allen
http://www.emesystems.com
mailto:tracy@e...
outside.
-- best regards
Tracy Allen
mailto:tracy@e...
tooling.
Short runs I would use a end mill and machine the slot with a
Bridgeport or such.
If it's one-out and you don't have a mill then you could drill some
holes and file the slot to size.
> outside.
> -- best regards
> Tracy Allen
> mailto:tracy@e...
> from the same email address that you subscribed. Text in the Subject
> and Body of the message will be ignored.
__________________________________
Do you Yahoo!?
The New Yahoo! Search - Faster. Easier. Bingo.
http://search.yahoo.com
your tube in your lathe, clamp your die grinder in the tool post, and use
an appropriate sized burr. Stainless is a bit tricky to work with, I would
suggest trying to create your slot on a scrap piece first. Drilling a
series of holes with a drill and use a very small hand file to finish is
another (albeit not elegant) solution. Maybe a small grinder wheel in your
die grinder held perpendicular to the axis of the tube would work, I'm not
sure how thick one of those are. Or make a three axis mill using the stamp
for control and use a couple temp and humidity sensors to calculate the
expansion rate of the stainless and compensate for the difference (just
joking) [noparse]:)[/noparse] Dan
| | tracy@emesystems.|
| | com |
| | 05/20/2003 04:55 |
| | PM |
| | Please respond to|
| | basicstamps |
| To: basicstamps@yahoogroups.com
| cc:
| Subject: [noparse][[/noparse]basicstamps] tooling telescoping tube
outside.
-- best regards
Tracy Allen
mailto:tracy@e...
> outside.
A mill with an endmill would be the 'proper' tool for the job. For a
one-of prototype, you could use a dremel.
For production quantities, you should look into laser or waterjet
cutting.
Mark Hillier, VE6HVW
President, HVW Technologies Inc.
Canadian Distributors of Parallax Products and other Neat Stuff
Tel: (403)-730-8603 Fax: (403)-730-8903
http://www.HVWTech.com
** New Breadboard Voltage Regulator (BVR) -A plugable +5 Volt
power supply !
if you have a lathe, use a jewelers saw.
you can easily make an arbor for a 1" saw.
you can buy either the full size or a smaller one and take a couple
cuts.
I just made a collet for my router and it went very easy.
since you can turn the lathe very slow (you need to cut slow) it is a
piece of cake.
if you want some drawings or picutes, let me know.
I make a sqare holder for the tube and held it in the tool post, then
just fed it in to the part with the cross slide.
it went very smoothly and would be easy to do if you have even
minimal lathe experiance.
An alternative method would be to hold the tube the same way, but use
an end mill of the final size. you would feed the carrage to
penetrate the tube with the mill, and then feed the carrage to the
lenght you need. this too is pretty simple.
Dave
have
starting
side
end
> outside.
> -- best regards
> Tracy Allen
> mailto:tracy@e...
I'll cut you one on our laser. It isn't a rotary (which would be
preferred) but we could do what you are talking about. We call that
'Government' work. The stuff you don't pay for [noparse]:)[/noparse]
-John
>outside.
> -- best regards
> Tracy Allen
> mailto:tracy@e...
easy to find 1/8" endmills, but smaller ones are $$$. Doubtful an of the
Dremel bits would cut the stainless cleanly.
The trick may be to mount the tube on the cross slide of the lathe and use a
reinforced Dremel cutoff disk chucked in the lathe to cut the slot.
> outside.
clamp the part onto the toolholder / carriage
put a 1/16 center drill in the chuck
poke holes for the rough slot, then use the center drill as an end mill
to clean up the slot on the z axis.
Run high r's, use coolant, if it's 300 series stainless take big bites
or get a bunch of those center drills. Good thing they're double
ended.
--- Rodent <daweasel@s...> wrote:
> Kinda tough due to the dimensions, especially if it has to be
> accurate. Its
> the
> and use a
> have
> starting
> side
> end
> > outside.
Do you Yahoo!?
I looked at the end mills in McMaster-Carr catalog, and find that
most of the ones less than 1/8" diameter are carbide. (=brittle? You
break it you buy $$ another.) There are a couple in highspeed steel
with TiN surface hardening. But I would still not know what to buy
one, two three, four flute, straight flute spiral flute? There are
also woodruff key cutters of the right thickness, and some small
slitting saws. Some of you also suggested grinding tools (at high
speed?) and a jeweller's saw. (is that a kind of blade?).
I don't know how fast to run the tools for SS. Do you go in a little
ways and then go along the length of the cut, and then a little
deeper along the length, or do you go all the way through at one end,
and then cut the length all the way through? With cutting oil? I'm
more used to brass and to plastic.
I do want a nice smooth, straight cut. I know the workpiece has to
be held very rigid. I do have a lathe, an old Myford (not numerical
by a long shot!). It has a nice smooth cross-slide, and I also have
a vertical slide, and a v-groove holder and assorted dogs and clamps.
-- best regards,
Tracy
endmill -- its takes some serious RPM. The abrasive or slitting saw would be
best. You just work really slow and make small cuts.
One other method mentioned by others was to mount the tube in the chuck on
the lathe, lock it so it can't rotate, then mount a Dremel tool on the
toolpost. This would give you the accuracy and speed.
Why not use some hall effect sensors? No slots or switches needed then.
You only need some small magnets to mount at choice places on the tube(s),
then when the magnet moves in close to the hall effect sensor, the MCU can
pick up on this and stop/start whatever. I got my magnets from a guy on EBAY
who had some really small ones too.
Although many of you missed out on on DPRG's Ralph demonstrating a neat
PCB cutter using a dremel tool mounted on a fabricated frame. This would be
a good approach. You make up a board and frame with a dremel tool mounted on
it so that the dremel can slide back and forth, then clamp down the PCB or
tube in this case. Next you fire it up and carefully move the dremel long
the PCB or tube as far as is needed.
From: Rodent [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=roZ8jxn4hS5W2M5bPQzh0b8yzPKZOu5zjcxKPK1XA0kw8UOR94HuAT_8Hm11YXQPUMKIJbqj6AK1fQ]daweasel@s...[/url
Sent: Wednesday, May 21, 2003 6:25 AM
Subject: Re: [noparse][[/noparse]basicstamps] tooling telescoping tube
Chances are your lathe can't turn fast enough to deal with the small
would be
chuck on
the
The endmill does not need to run fast at all. each flute will take
roughly 0.001" or metal, so a 2 flute end mill will take roughly 500
cuts per inch. at 500 RPM, it would take a full minute to cut a one
inch lenght. at 250 RPM, twice as long.
the Dremel will spin at roughly 25,000 RPM as compared to the lathe's
top end of about 3,000 RPM. mounting the Dremel on the tool post
would be better if you wanted to go this route. A word of caution is
to cover all the ways with rags whenever grinding near them, then
clean off everything to get any bits of grinding dust off.
Dave
You
steel
buy
are
little
end,
I'm
to
numerical
have
clamps.
Quite brittle. Works well for most materials IF the setup is rigid.
> There are a couple in highspeed steel with TiN surface hardening.
Good way to go for GP use.
> But I would still not know what to buy one, two three, four flute,
Usually you'd choose two flute mills for plunge cuts, four flutes
for milling (faster, or better finish). Spiral flutes most apps,
faster spiral for softer material.
Cutoff wheels are usually the cheapest solution if you can
live with the tolerance and finish.
Look in Handbooks under "Feeds & Speeds". SS thermal conductivity is
low, so heat buildup work-hardens the piece ahead of the cutter...
regards, Jack
Another supplier of cutting tools you may wish to check
out is www.use-enco.com. They have an online catalog and
ordering and you may find their prices a little lower.
Stainless can be difficult to machine in a small home type shop
because of it's work hardening properties. The thin wall of the
tube shouldn't be too difficult though. As another has already
suggested, feed the cutter as aggressively as possible. Real
fine feed and slow cutting leads to the work hardening problem.
Use plenty of coolant. In my home shop, this means a steady
stream of wd40. Not good for much else, but it makes a reasonable
coolant for us home shop guys.
Success will also depend on how rigidly you hold the tubing.
You might try machining a piece of aluminum rod to be a nice
push fit into the tubing. This would allow you to solidly clamp
the tubing horizontally in your vertical slide and reduce the
burr from cutting. Another product called Cerrosafe Alloy would
lend itself nicely to this job. Cerrosafe is a low temp alloy that
melts between 158-190 deg F. You melt it, fill the piece of tubing,
do the machining, then simply melt it back out for reuse. This
would allow very rigid holding either horizontally or vertically in
your vertical slide.
I would suggest carbide end mills. 2 or 4 flute will work, just make
sure they are center cutting (allows you to drill a hole like a drill bit).
The 4-flute would require less rpm to get the same surface feet per
minute cutting speed compared to the 2-flute.
The end mill should be available in .09375 diameter and not too
expensive (Enco322-6006~$4.50). M42 cobalt would be my second
choice (Enco321-9515~$6.00).
Remember, the softer the material, the faster the bit should turn,
and the harder the slower. SS is pretty hard, so a slower rpm
would be called for, but since the cutter is such a small diameter,
it can still be run at a pretty high rpm. I would try 1000+ rpm.
You will have to experiment to see what works best for your
setup and cutter combination. I find that I can seldom run at
the suggested SFPM as quoted in the professional machining
references. I have much better luck slowing things down to
even half the suggested rates. Our small home shop equipment
usually doesn't have the rigidity and control required for the
higher cut rates.
Hope these ideas help,
Dennis
> >starting
> -- best regards,
> Tracy
> Tracy,
The problem of work hardening is caused by 2 things. one is
excessive heat that is heat treating the metals. the other is a dull
cutter pushing the metal, besides heat, it compresses the surface
making it more dense.
Speed has little to do with it and slow speed will not result in work
hardening if the bit is sharp. much like a hand file will not cause
the problem of work hardening.
One of the probems with feeds is that cutters need to work is some
specific way. Carbides have edges that are duller due to the fact
that they are brittle. razor point edges will break ruining the
bits. but, they can handle deeper cuts per flute and will last much
longer. so a heavier feed for carbide is recomended.
Personally, I could be concerned with carbide on such a small cutter
as they are prone to snap more easily than HSS or cobalt.
cobalt is a great choice as it is often much harder HSS and wears
much longer.
lubracation for cutting on this type of part is for cooling the part
and cutter as well as cutting lubracation. a drip oiler will work
great and you can just stop occasionally to refil it. if you catch
the old oil, you can just pour it back in and let it drip again,
chips and all. or you can filter it thru a cloth and get the big
chips out.
the idea about work support is dead on. as you mill the slot, the
part will naturally become weaker. an internal support or external
clamp will work, if the external clamp is more like a collet than a
vise.
Dave
drill bit).
> higher cut rates.
> Dennis
wall,
has to
> > >starting
You
steel
buy
are
little
end,
I'm
to
numerical
have
clamps.
> > -- best regards,
> > Tracy
try to mount the part to be worked on the lathe so that it will be
rigid and not deform from the clamping pressure. The maximum speed
of this lathe is 745rpm. We only have to do four of these as
prototypes.
I didn't know that laser could work on this relatively thick
material. (0.029" wall), and I don't know the economies of it. I
guess when we pay $500 for a solder-paste stencil for a surface mount
board, they probably cut that thin stainless steel material on a
laser, from the Gerber file?
The reason we are cutting the slot, instead of using a magnet to
sense the position, is that we need to restrict the travel and
prevent rotation of the tubes. The screw projecting through the slot
kills two birds with one stone (at least that is the idea), because
it can also activate the detector switch when the slotted tube is at
one end of its travel. There is a spring inside the outer tube that
determines the activation force.
-- best regards
Tracy Allen
mailto:tracy@e...
I'm intrigued by this. Can you really cut material of this
sort,.029" 304SS, on a laser? What is a "rotary"? If not rotary,
what is it?
-- Tracy
>If all else fails, send me a foot or so of it (I need to practice too!) and
>-John
>>outside.
>> -- best regards
>> Tracy Allen
> > mailto:tracy@e...
farm out a complex design and have it done quicker and much, much cheaper
than if we did it with a mill. I'm not a laser expert, but our supplier
can cut up to 1/4"? and using materials that would be a bugger using a mill
(temper, stainless, etc.). If they had a rotatory table hooked up to their
laser they could easily do spiral cuts in tube, etc. I'll let the experts
fill in the details. A quick search on the web should show some cool stuff
they can do. Most larger cities have a couple laser cutting shops. Does
Parallax use laser to cut out their robot chassis? We often use 'puzzle
piece joints' when we need to cut sections that are too large for the laser
and the pieces fit together, well, like a puzzle.
Hi John,
what is it?
-- Tracy
At our facility we have several laser cutting machines, some of which
are capable of cutting 304SS thicker than 0.200".
We can even cut mild steel up to 0.750" thick.
I'm not sure what John means by rotary laser.
However, we do have a 5-axis laser that is capable of cutting
irregular shaped materials including tubing.
As to the economy of laser cutting...
We charge about $135.00 per hour (setup, programming, and cutting
time) for most jobs.I think the 5-axis laser is about $175.00 per hour.
It can be economical for flat material because you can cut a lot of
material in an hour, however the irregular shaped material can take
much longer if each piece has to be set-up individually. It depends on
the precision required on some jobs.
Mike W.
> Hi John,
> what is it?
> -- Tracy
too!) and
> >-John
> >>outside.
> >> -- best regards
> >> Tracy Allen
> > > mailto:tracy@e...
laser, from the Gerber file?"
We currently have CO2 lasers that will cut 1/2" Stainless steel (3000
watts) and are soon to buy another that will cut 3/4" Stainless (5000
watts)
0.029 is easy! [noparse];)[/noparse]
John
I didn't see this post before I put up the last one, but check this out:
http://www.us.trumpf.com/31.tcl3050.html
A 'rotary' is an additional axis that goes on a machine like this that
looks kind of like a lathe, it turns the material, while the laser beam
cuts from above, the rotary takes care of the rotational axis movement,
and the laser moves in the other axis (2 axis cutting) there is a third
axis, but that is only for keeping a predetermined distance away from
the material. There are full 5 axis machines, those are used for stuff
like trimming automotive panels after they are stamped (no, not basic
stamp[noparse]:)[/noparse]
Finally, something I know something about on this list! Off topic none
the less! [noparse]:)[/noparse]
-John
From: Tracy Allen [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=o7X89vNIMWWpHetXwKjf9FMOF6HJ_HA2jejsBETnSrKxDigRb7i6fltmU-FAB4BvMvh_C_v9DC_lSkwLcg]tracy@e...[/url
Sent: Thursday, May 22, 2003 1:08 PM
Hi John,
what is it?
-- Tracy
and
>-John
>>outside.
>> -- best regards
>> Tracy Allen
> > mailto:tracy@e...
12,000 inches per minute ?
resolutions down to 0.001" or better ? man that feedback must be
something to handle the PID on postioning from an encoder and moving
parts.
I have to assume it has more than a half dozen servo's moving things
around.
And YES, Tracy, this will cut your tube with precision you may not be
able to measure. and, if you want a radius on the end of the slot,
it could do that, a square end, or even the EME outline. darn nice
machine.
Dave
--- In basicstamps@yahoogroups.com, "John Walton" <john@l...> wrote:
> Tracy,
out:
that
beam
movement,
third
from
stuff
basic
none
> -John
> From: Tracy Allen [noparse][[/noparse]mailto:tracy@e...]
> Hi John,
> what is it?
> -- Tracy
too!)
> and
that
> >-John
have
to
starting
side
end
> >>outside.
> >> -- best regards
> >> Tracy Allen
> > > mailto:tracy@e...
Subject
I had some aluminum parts cut by laser, wound up to be around $2.00
to $3.00 each in lots of 25, and that included the sheets, and
bending !
the parts were around 8" long, by 3" by 0.08" thick.
once you get your prototype, look into having them made. I assumed
you were doing one for your home telescope with CCD and all that
stuff.
Dave
> Thanks for all the good advice. I'll order a couple of cutters and
> prototypes.
mount
slot
at
that
> -- best regards
> Tracy Allen
> mailto:tracy@e...
>That is one scarry machine !
Sounds scary, you should see it, unbelievable.
(This thread is off topic, so I'll shut up after this post unless someone
asks something specific)
-John
> Hi Tracy,
which
Rotary is either that the cutter can rotate or that the part can
rotate.
but if you already have a 5 axis, you have that capability.
prices seem about right. $175 an hour plus metal. and since you
guys buy in bulk, it cost me less to have parts made than to buy the
metal !
Dave
hour.
on
> Mike W.
> > Hi John,
rotary,
> > what is it?
> > -- Tracy
> too!) and
that
> > >-John
might have
wall,
has to
starting
side
grinder.
and a
slot
the end
from
> > >>outside.
> > >> -- best regards
> > >> Tracy Allen
> > > > mailto:tracy@e...
