Serial question about DEBUG and using SERIN on port 16 BS2P
Archiver
I have some code that worked on port pin 0 and 1 but I decided to use the
DEBUG port to cut down on parts and pin requirements. Debug sends my data
out as expected but when I use SERIN with a pin argument of 16 I get a
strange artifact. The serial port echos each character back as it comes in.
I assume there is no way around this short of modifying the stamp hardware.
Is that loopback required for the programming function?
Stamp's programming port. It's not too tough to work around this by having
your external app filter the echo.
-- Jon Williams
-- Parallax
In a message dated 5/20/2003 2:09:52 PM Central Standard Time,
larrysr@m... writes:
on the BS2. They use the Tx-In signal voltage to
drive the Rx-Out signal. And no, there's no way
to defeat it (this from earlier Parallax people's
posts).
Ignoring the echo has been the recommendation.
--- In basicstamps@yahoogroups.com, "Larry G. Nelson Sr"
use the
my data
get a
comes in.
hardware.
