PH Sensor w/ ADC w/ stamp
Hello,
This message was sent to the owner instead of the list itself, so I'm
posting it for Dominick.
Erik Wood
ewood@p...
From: DZappia [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=uc9B3Ncgggl6M1mUWlk-21NgaXjduKJsY6q7PPpGI2bvVqC0pX2eVx78ow1Mde2FQYPmV5X6fOcaWbgk]dzappia@y...[/url
Sent: Sunday, May 18, 2003 8:43 PM
To: basicstamps-owner@yahoogroups.com
Subject: Re: PH Sensor w/ ADC w/ stamp
Hi Dale,
I came across this message thread and thought you could help, if you
have the time. PH Sensors provide millivoltage to representing the
current pH of a solution ranging from negative to positive numbers
corresponding to 0 to 14 pH. I have no trouble reading the positive
values, but whenever the pH drops below 7, into the negative range, I
get nothing but 0 from my ADC0831 output. Can you help??
Thanx alot
Dominick Zappia
dzappia@o...
Here is the portion of the code that handles the sensor readings, if
it helps...
sensors:
debug cls
high CS ' be sure CS is high
low CS ' initiate the conversion
low CLK
pulsout CLK,210
shiftin AData, CLK, msbpost, [noparse][[/noparse]ADres\9] 'shift in the data
debug "Sensor Reading V: ", DEC ADres */ $139C DIG 3, ".", DEC3 ADres
*/ $139C, CR
debug "Sensor Reading V: ", DEC3 ADres */ $139C, CR
debug "Sensor Reading V: ", bin8 ADres
serout pin, baud, [noparse][[/noparse]bin ADres, CR]
goto mainloop
Erik Wood
ewood@p...
Hi Dale,
Thanx alot
Dominick Zappia
dzappia@o...
it helps...
sensors:
debug cls
low CLK
pulsout CLK,210
*/ $139C, CR
goto mainloop
One solution is to provide a virtual ground for the pH
probe/amplifier. So, at pH=0 the output level would be 2.5 volts.
Then you could read both + and - pH values.
pH probe (+)
|amplifier|----|ADC|---- stamp
pH probe (-)--;
+2.5 volts
instead of:
pH probe (+)
pH probe (-)--;
common
the amplifier, ADC and Stamp are referenced to common in either case.
Other options are to change the amplifier, so that it provides the
offset, or change to a different ADC that allows both + and - signals.
-- best regards
Thomas Tracy Allen PhD
http://www.emesystems.com
mailto:tracy@e...
>From: DZappia [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=0Ju-KMCJ7wQWk6EkSP2szgYYIyQUSTouJcOUal7n1ruJxzx2Sj1f1MiXaM7on7sZeElbctFm7e5Tt50]dzappia@y...[/url
>Hi Dale,
>Thanx alot
>Dominick Zappia
>dzappia@o...
>it helps...
>sensors:
>debug cls
>low CLK
>pulsout CLK,210
>*/ $139C, CR
>goto mainloop
