Com port configuratin — Parallax Forums
edited 2003-05-19 22:17 in General Discussion
Where can I get more information about com port configurations? I am
using a lap top that requres an adaptor from a 25 pin to 9 pin
cable. The Basic Stamp Editor shows a connection on COM3 but can't
find the stamp ("No Stamp Found"). Any suggestions on how to trouble
shoot this?
    edited 2003-05-19 13:52
    If it is a female-type DB25 (it has sockets)
    on the back of the PC then that is a
    parallel printer port.
    If it is a male-type DB25 (it has pins)
    on the back of the PC, and
    you are using an off-the-shelf DB25 to DB9
    adapter, then the cable must be straight
    through (no null modem).
    I haven't seen a DB25 Male port on a laptop
    in several years -- maybe your's is an old
    one?
    Usually the hardware COM port on a laptop
    comes out COM1 -- COM3 is typically not used,
    and COM2 is typically a modem (if installed).
    Personally, I've installed a USB serial
    adapter as Com3. Com3 has also been used
    as the IR-port, on newer laptops.
    If this doesn't answer your questions,
    next time tell us the year, model, and
    vendor of the laptop, and what you
    have your BS2 plugged in to (BOE,
    etc).
    --- In basicstamps@yahoogroups.com, "mikeschnobrich" <mjsnow@d...>
    am
    trouble
    > shoot this?
    > Mike
    edited 2003-05-19 14:17
    Laptops can be such fun to set up because many not only have a serial port,
    but also an I/R port and possibly a built-in modem. In a Windows environment
    it can be real fun to get it all working. Tell us more about the laptop and
    we may be able to assist further.
    It may be worth noting that many of the DB25 to DB9 adapters / converters
    (not cables) do not work for anything but a mouse. All of the necessary
    lines are not passed from one end to the other.
    Pins 3 & 4 on a standard DB9-DB9 and DB25-DB25 cable will be straight
    through. On a standard DB25-DB9 cable they will cross. Null cables will be
    just the opposite.
    > one?
    > etc).
    > am
    > trouble
    > > shoot this?
    Does the laptop have "FIFO" enabled for the COM port? I use a Toshiba
    laptop and, just before I installed the stamp IDE, someone answered a
    previous question about having to disable it on a Toshiba to get the
    communications with the stamp going. I did the same, and it's worked for
    me. On NT, FIFO is an advanced setting for a COM port.
    I never tested with FIFO enabled.
    hth
    From: mikeschnobrich [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=LpojF9fwBWlXxJ7AenUJkjiPvaWyQ_XpTq_IPgAWh8ngP5GAJi-ZBZtxvMfY0Kq_WF4LAq3lz0cekJx1Iw]mjsnow@d...[/url
    Sent: Sunday, May 18, 2003 10:52 PM
    Subject: [noparse][[/noparse]basicstamps] Com port configuratin
    shoot this?
