Package converter
how do people use SOP(small outline package) , QPK,
LCC pakage type ICs for prototyping : as breadboards
are normally for DIPs . Can anyone pls explain/advise
as to how i can interface various SOP ICs that i need
to use with my STAMP which can easily be inserted in a
breadboard. Are they some pakcage convertors available
and if so how do they handle different pin counts
__________________________________
Do you Yahoo!?
The New Yahoo! Search - Faster. Easier. Bingo.
http://search.yahoo.com
Do you Yahoo!?
are talking about. Sorry I don't remember exactly what they were called or
I would give you a link. But you are on the right track.
-John
>Do you Yahoo!?
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
have a copy at work.
From: John Walton [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=0ySLs5IZ8uzpD-fT5z_NGDQsPty59ttpXZWP4orzsg3LNwxqYm_EiuJdPz2oxizP3GBmUrOQi7jd]john@l...[/url
Sent: Saturday, May 17, 2003 10:03 PM
Subject: Re: [noparse][[/noparse]basicstamps] Package converter
I've never used them, but I noticed www.jameco.com carries just what you
-John
>Do you Yahoo!?
If you don't mind a little extra soldering you can get some snap apart
converters at:
www.beldynsys.com
I was looking for some converters also and found that a SINGLE SMD to
DIP converter for an SO8 can cost from 5-10 dollars (i needed about 5)
. At Bellin you can get 140 for $50! Of course "some assembly is
required" (you have to solder on the DIP pins, easy compared to
soldering on the SO8!). You can also get a snap apart board that has
a 8,14,16,18,20 pin selection.
jameco also carries some of the Bellin stuff also.
Chuck Chargin Jr.
--- In basicstamps@yahoogroups.com, harshit suri <suri_list@y...>
> Do you Yahoo!?
