help!!!! i WANT MY MOVIE CAMERA TO RUN IN SYNC WHAT SHUOLD...
STOP SHOUTING!!! <grin>
Okay ... to your "problem." If you shoot movie film at 24 frames per minute,
instead of 24 frames per SECOND (normal frame rate), you're going to end up
with a time lapse effect -- everything will appear on screen 60 times faster
than in real life.
With the BASIC Stamp you can create a simple tachometer to measure your
shutter speed. What you would have to do is insert a light source and
receiver source on the opposite side of your aperture, such that the shutter
(assuming a 180 degree shutter) interrupts it.
This may end up being more work than necessary, though. Most 16 mm and
larger film cameras allow for crystal sync input so that the camera can be
synced with an external audio recorder. If yours doesn't, you'll end up
having to intercept the motor control voltage and use a PWM and circuit to
control the speed.
-- Jon Williams
-- Parallax
In a message dated 5/17/2003 10:44:50 AM Central Standard Time,
xxxaxpxxx@y... writes:
> HI CAN SOME ONE PLEASE TELL ME WHAT I CAN ADD TO MY MOVIE CAMERA SO
> THAT IT RUNS AT PIN PIONT SPEEED? IT RUNS OFF A 7.2 VOLT BATTERY, i
> WANT PULSE POWER GOING TO IT SO IT ALWAYS RUNS AT 24 frames per
> minute exactley. also i would like to know if theres a led read out i
> can add that shows a speed or a marker or beeps so i can calibrate
> it? what tool can i use to measure the speed of a dc motor? i know a
> strode light is used on movie cameras but I dont have $2000.00 to buy
> one, so im looking for a metter of some kind but not sure the
> kind??? thank you so much for all your help!!!
than in real life.
control the speed.
-- Jon Williams
-- Parallax
