Converting a number to ascii character
I am using the Basic stamp 2 and I was wondering how I can convert a
number ie. 50 to Ascii 5 and 0.
I need to display a counter decreasing from 60 seconds down to 0 on
an LCD display
Thank you
-M
an LCD display
Thank you
-M
display, you have to do a bit of work:
char = (seconds DIG 1) + 48 : GOSUB LCD_Write
char = (seconds DIG 0) + 48 : GOSUB LCD_Write
The '+ 48' is what converts a single-digit value to its ASCII code. If you
have a serial LCD, you can user built-in formatting:
SEROUT pin, baud, [noparse][[/noparse]DEC2 seconds]
-- Jon Williams
-- Parallax
In a message dated 5/16/2003 7:44:52 PM Central Standard Time,
mdbware@h... writes:
> an LCD display
> Thank you
> -M
I found the solution on one of the postings, this is what I did.
for Index = 2 to 0
char=(t1 dig iNDEX) + "0"
gosub lcdWr
next
Thank you
-M
--- In basicstamps@yahoogroups.com, jonwms@a... wrote:
> Depends on the kind of LCD you have: parallel or serial. For a
parallel
code. If you
> -- Jon Williams
> -- Parallax
convert a
on
> > an LCD display
> > Thank you
> > -M
