Ckt to answer telephone — Parallax Forums
edited 2003-05-15 17:13 in General Discussion
Hi. Well I have my stamp hearing DTMF tones, and evrything from that
point on is great. Now, i have a question about the pre-stamp part:
Can anyone point me to a resource that will show how an answering
machine works? I understand that the voltage on the line changes
when the phone "rings", and so on and so forth... I want to be able
to call my stamp, have the stamp answer (ideally after some number of
rings, but instantly is ok).
I'm about to go find an old answering machine to disect, but in the
meantime I was hoping someone here might have some experience with
phone stuff.
TIA!
chris
    edited 2003-05-14 20:44
    Larry Gaminde
    Sent: May 14, 2003 10:12 AM
    Subject: [noparse][[/noparse]basicstamps] Ckt to answer telephone
    > phone stuff.
    > TIA!
    > chris
    edited 2003-05-14 22:05
    Yes, a standard Modem does this.
    You set it up to 'auto-answer', and raise a line
    on the BS2 when it has connected. I believe you
    can send DTMF tones down the line (with 'dial'
    commands). Now the only issue is: how do you
    connect the stamp line so it 'hears' the DTMF
    coming back from you?
    --- In basicstamps@yahoogroups.com, "iamlevis2" <iamlevis2@y...>
    that
    able
    of
    > phone stuff.
    > TIA!
    > chris
    edited 2003-05-14 22:30
    First of all, if you are going to connect a device to the telephone line,
    you are supposed to do it via a DAA (Data Access Arrangement) - a device to
    protect the phone line from your device. I don't know if you still get them
    from the phone company or not.
    However, if you are going to connect to the phone line, you need to be
    careful. When the phone line is idle ("on hook"), the phone line voltage
    will be around 48 volts DC. You can't draw any amount of current from it in
    this state - I think the load is supposed to be around 10 megohms or so.
    When the phone rings, there will be an AC voltage - around 90 volts or so,
    as I recall - I forget the frequency, but is relatively low - 100 hz or
    thereabouts.
    In order to detect a ring, you need to use a full wave bridge rectifier,
    isolated from the line via a capacitor. You can filter it, and use a
    voltage divider to drop the DC voltage down to 5 volts for the PIC input pin.
    To answer the phone, you need to put a load across the line - I've used
    600-900 ohms before.
    I expect if you do a Google search, you will find a lot of info about this.
    >phone stuff.
    >TIA!
    >chris
    Larry Bradley
    Orleans (Ottawa), Ontario, CANADA
    edited 2003-05-14 23:21
    One cheap way to safely detect the ring is to put a NE1 neon bulb across the
    phone line and use a phototransistor tied to the Stamp pin to sense when the
    bulb is lit. The neon bulb will flash when the phone rings (although it may
    blip every once and a while when the phone is picked up or hung up).
    > phone stuff.
    edited 2003-05-15 00:32
    Well, i have the bs2 hooked up to a dtmf decoder. with a tone
    generator, i've confirmed that the stamp now knows when i push a
    button, and what button was pushed (thanks to the help of the list).
    this is all gonna get stuffed into a little box. no pc, just power
    and phone. so:
    1) phone rings
    2) stamp counts rings
    3) when (eg) rings=3, whatever stuff has to be done will take
    the "virtual-phone" off-hook
    4) the stamp listens to the tones i push, and does stuff
    ... something something.
    --- In basicstamps@yahoogroups.com, "Allan Lane" <allan.lane@h...>
    > that
    part:
    > able
    number
    > of
    the
    with
    > > phone stuff.
    > > TIA!
    > > chris
    edited 2003-05-15 04:20
    see
    http://www.microengineeringlabs.com/downloads/LABXTSCH.PDF
    is everything you ever wanted to do with a telephone line and has examples in
    PicBasic Pro which are compatible with Stamp BS2
    http://www.microengineeringlabs.com/downloads/XTDOCS.ZIP
    Sent: Wednesday, May 14, 2003 7:32 PM
    Subject: [noparse][[/noparse]basicstamps] Re: Ckt to answer telephone
    > and phone. so:
    > 1) phone rings
    > > that
    > part:
    > > able
    > number
    > > of
    > the
    > with
    > > > phone stuff.
    > > > TIA!
    > > > chris
    edited 2003-05-15 14:30
    The reason I recommended a Modem is that the phone
    company has various requirements regarding what
    you may attach to their lines -- which a Modem
    already has built in.
    Note that the Parallax modem board is on sale at
    $99.00, and has all the components you need for
    direct connection to the phone line already
    put together.
    The Phone article recommended in the post shows how you
    can then couple your BS2 pin directly to the phone lines,
    once the Modem has taken them off-hook, so you can
    listen to the DTMF tones with the BS2. It looks like
    capacitive coupling, with 0.1 uF 250Volt caps and
    250 KOhm resistors is what you need.
    I really think the phone line interface, and meeting
    the phone company's requirements, is the hardest part
    of this project, which the Modem Kit would solve
    out of the box.
    > and phone. so:
    > 1) phone rings
    from
    > > that
    > part:
    answering
    changes
    > > able
    > number
    > > of
    > the
    > with
    > > > phone stuff.
    > > > TIA!
    > > > chris
    Very good. I'll look at the modem kit. That's probably the best way
    to do it.
    Thanks for the help.
    > put together.
    > out of the box.
    list).
    power
    > > and phone. so:
    > > 1) phone rings
    <allan.lane@h...>
    <iamlevis2@y...>
    > from
    > > > that
    stamp
    > > part:
    > answering
    > changes
    be
    > > > able
    > > number
    > > > of
    in
    > > the
    > > with
    > > > > phone stuff.
    > > > > TIA!
    > > > > chris
