limiting current on LED''s (slightly off topic)
Understand. You might try some of the surplus folks, or MPJA, Mouser.
Good luck.
From: Rodent [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=VSy-e3iMi7K61Rok_-XzaXZVNGFj5q7iuQHr5-_1ulCZK5TYQoBrnemqrmFE8OssWVwyLpokWMEGrV0DIw]daweasel@s...[/url
Sent: Wednesday, May 14, 2003 12:05 PM
Subject: Re: [noparse][[/noparse]basicstamps] limiting current on LED's (slightly off
topic)
Unfortunately the LED's with the dropping resistor are a bit pricey -- I
think last time I checked they were about $1 or so, which is about 3x as
high as buying a standard LED and a resistor.
> Or, you can just buy the leds with the limiting resistors in place,
> installed inside the led housing. Digikey or Newark has them.
Your use of Yahoo! Groups is subject to
Good luck.
topic)
