A good, inexpensive PS I''ve found
Rodent,
Remember your Ohm's law. A 5 ohm resistor will draw 1 amp from a 5 volt
supply. It will also dissipate 5 watts of heat. So a 10-watt, 5-ohm resistor
across the 5-volt output of the supply should do the trick. Be aware that
this WILL heat up a bit, so don't put your finger on it while it's running,
and don't let anything flammable touch it. I'm not sure what the delta-t
will be for that resistor, but it will probably get up to 100 plus degrees
F.
Mike Sokol
www.modernrecording.com
mikes@m...
Sent: Tuesday, May 13, 2003 11:55 AM
Subject: Re: [noparse][[/noparse]basicstamps] Re: A good, inexpensive PS I've found
> Well, that blows me out of the water. I'm lucky if many of my Stamp
projects
> draw a couple hundred ma. The other AVR stuff draws even less.
> As far as the PC power supplies, we need to define "old." The really old
63
> watt and 100 watt XT / AT supplies did need a load. Not sure about the
later
> non-ATX models though.
> > 1 amp load on the 5 Volt line will make most (that I have seen anyway)
> > computer power supplies come up.
> > The newer ATX power supplies need a load to let the monitoring
> > cirucit turn on the power supply.
> > older power supplies don't need a load to start.
> > > Isn't it true that you always need some load on computer power
> > supplies to
> > > work/regulate.
> > > Seem to me I read something about this in N&V some time back. Also how
> > > would you regulate/limit the current so not to blow
> > anything or in
> > > my case blind by the light when (not if) I short something out.
> > Just can't
> > > trust us mech types with electricity/
F.
Mike Sokol
mikes@m...
projects
63
later
> > supplies to
> > > work/regulate.
> > anything or in
> > Just can't
