Reading RS232 scale
I have a digital scale with RS232 but cannot understand how to use
the data in the scale's manual to write the code for my BS2. The
manual states the followig:
Speed: 2400 bps
word length; 8 bits
parity: non
stop bits: 1
Data format: (LF)(sign)xxxx.xxx(unit)(LF)hh(ETX)
LF = is ASCI line feed
ETX = ASCII end-of-text
unit = can be "kg", "lb", or "oz"
sign = can be "+" or "-"
xxxx.xx is the weight read by the scale
hh is a two-byte scale status:
high-byte:
bit 0 high = scale in motion
low = scale stable
bit 1 high = scale at zero
low = scale not zero
bit 2 Not used
bit 3 Not used
Low-Byte:
bit 0 high = scale under capacity
low = scale not under capacity
bit 1 high = scale over capacity
low = scale not over capacity
bit 2 Not used
bit 3 Not used
I used 16780 for baud rate after checking with the version 2.0
manual and then tried all kind of different variation of the Serin
command with no luck. I just get rubbish.
Any help as to how to structure the Serin command to receive the
above sequence of information?
many thanks in advance...
AL
Speed: 2400 bps
word length; 8 bits
parity: non
stop bits: 1
high-byte:
low = scale stable
bit 2 Not used
bit 3 Not used
Low-Byte:
bit 2 Not used
bit 3 Not used
AL
SERIN ... [noparse][[/noparse] byte1,byte2,dec4 word1, ".", dec3 word2, byte3, byte4,
byte5, hex4 word3, byte6]
Now:
Byte1= 10 (sanity check)
Byte2= +/-
Word1=integer part of weight
Word2=fractional part of weight
Byte3=k,l, or o
Byte4=g,b, or z
Byte5=10
Word3=status word (I'm assuming hh is 4 hex digits?)
Byte6=ETX (sanity check)
You can check Byte1,5, and 6 to make sure you have a good frame. You
can't really sync reliably on the LF because it occurs twice. However,
if you see a bad frame you could start reading bytes until you get an
ETX and then discard it all and go back to waiting for a frame.
This is all off the top of my head and may not be exactly right, but it
ought to be close.
Al Williams
AWC
* Easy RS-232 Prototyping
http://www.al-williams.com/awce/rs1.htm
> From: brownstamp [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=7gEB7kXrU4Pjrx_oWKR5F_GA2-UHBaLk5BhDDi7oeWus-2Fvo-Y6ZwcaTPIaHtYLqzVWRlZMz5cVPPFsmA]brownstamp@y...[/url
> Sent: Sunday, May 11, 2003 4:58 PM
> Subject: [noparse][[/noparse]basicstamps] Reading RS232 scale
> Speed: 2400 bps
> word length; 8 bits
> parity: non
> stop bits: 1
> high-byte:
> low = scale stable
> bit 2 Not used
> bit 3 Not used
> Low-Byte:
> bit 2 Not used
> bit 3 Not used
> AL
> from the same email address that you subscribed. Text in the
If your scale uses "true" logic levels (an idle line would typically
read 5V), you'd need 396:
SERIN pin,396,[noparse][[/noparse]WAIT ($0A),sign,DEC ints,DEC frac,STR units\2...
At 2400 baud you should be able to liberally use the SERIN modifiers
to your advantage.
Steve
> the data in the scale's manual to write the code for my BS2...
