Newbie: Good old Car Computer/Data Logger
Archiver
Hi all,
Having been in and out of electronics all my life I find myself drawn back into
the fold thanks to these great little Basic Stamp things!
I'm trying to build a car computer/data logger type project using mainly ECU
inputs. Output will be a few leds as shift lights, some 7seg for large bright
rev display and a 2x20 serial LCD for the other display.
I have found on my travels of the world wide web many sites on the robots side
but very few, infact none, that discuss in any detail a car computer/data logger
project.
I've worked out all the output side of things and got what I consider some
nicely formatted leds and lcd for the display, it's just the inputs...
The first issue is revs... the PULSIN command and the 16 bit math causes the
issue that to get the right numbers you end up with 160 rpm resolution... I was
hopiong for 100 rpm resolution. Using COUNT and a 150ms time setting, I get the
100 rpm resolution but only 8Hz sampling rate!!! Surely there is a way of
getting a 50 Hz sampling rate with 100 rpm accuracy on a 4MHz Basic Stamp???
If anyone has any info on building a car computer, specfically working out the
gear based on the ratio of revs to road speed, please drop me a line... I plan
to do a very detailed website (my car website has over 1300+ build photos) so I
can share the knowledge back to the Internet.
As I say I am looking to do a data logger of the back of this using the
readings, hopefuly at 50Hz sampling rate for about 8 inputs...
Cheers for your help all,
Kev/.
P.S. If you're interested here's the car: www.kevp.com/rush
project.
Kev/.
I wouldn't know where to start to answer your questions, yet, though I have
some ideas. I am going to be in England (Exhall, Coventry) from 21 May to 2
June, on holiday. Is there a way we could get together to talk about what
you are trying to do? Maybe I could help you from there, since I understand
electronics well, also, having spend 30 years of my life in it
professionally. Also, there is a "Forrest Mims Engineer's Notebook" that
Radio Shack sells here in the US. If you can get your hands on it, it may be
a help. I have an old one (pre-Basic Stamp) that deals with what you are
trying to accomplish, but it uses almost entirely discrete components, since
it was published over 20 years ago. I believe I saw mention of an updated
version that would almost certainly deal with the Stamp. If you can get
ahold of their catalog, or even go to a local store (do they have Rat
Shack's in the UK?) I think you might find a wealth of help in it.
If you want to e-mail me offline in order to provide a means of getting
together, assuming you are close enough to the location to make it work,
maybe we can sit down over a cup (of coffee, on me, since I STILL haven't
gotten used to tea the way Brits drink it <g>) and discuss it.
Sent: Wednesday, May 07, 2003 10:00 AM
Subject: [noparse][[/noparse]basicstamps] Newbie: Good old Car Computer/Data Logger
> Hi all,
into the fold thanks to these great little Basic Stamp things!
ECU inputs. Output will be a few leds as shift lights, some 7seg for large
bright rev display and a 2x20 serial LCD for the other display.
side but very few, infact none, that discuss in any detail a car
computer/data logger project.
the issue that to get the right numbers you end up with 160 rpm
resolution... I was hopiong for 100 rpm resolution. Using COUNT and a 150ms
time setting, I get the 100 rpm resolution but only 8Hz sampling rate!!!
Surely there is a way of getting a 50 Hz sampling rate with 100 rpm accuracy
the gear based on the ratio of revs to road speed, please drop me a line...
I plan to do a very detailed website (my car website has over 1300+ build
photos) so I can share the knowledge back to the Internet.
> Kev/.
I don't know if I said it, but I am certainly impressed with your car. How
long have you been at it?
> Hi all,
> Kev/.
Thanks for the offer, its a bit far north for me but as I travel a lot with
work I'll see if I can find any jobs up that way!
I've not heard of the Forrest Mims books but Amazon.co.uk do sell them. I
get a copy and see.
I've done a bit more research and discovered the PAK-7 on the
www.al-williams.com website.
I've ordered a couple and I'm hoping these will solve my rev and speed input
issues.
I've also found the MAX186, an 8 channel A2D... does anyone use this or have
a BS2 code snippet?
I'm probably getting carried away for my first stamp project but I've also
seen some neat other addons like the ultrasonic measuring SRF04 and the
compass module!
I thought that a SRF04 on each corner of the car could measure the ride
height when the car is stationary... I'm guessing it can't range fast enough
to measure changes if the car was moving?
Kev/.
I'm pretty sure it wouldn't be able to follow the body as it jounces over
bumps, potholes, what have you. But it might be interesting to look at what
kind of squat, lean, dive, etc., you get in various hard lateral
acceleration/deceleration modes. And that knowledge might even help you to
tune the suspension for a better ride (whatever specification you might
apply as "better").
Sent: Thursday, May 08, 2003 11:23 AM
Subject: Re: [noparse][[/noparse]basicstamps] Newbie: Good old Car Computer/Data Logger
> Hi Mike,
with
> get a copy and see.
input
> issues.
have
> a BS2 code snippet?
> compass module!
enough
> Kev/.
what
I was hoping to get info on dive during braking, as such a light car can
suffer from too little rear braking.
Cornering lean would also be good, but I'm worried that the SRF04 won't
range quick enough or the general bumpyness of the road will put too much
noise on the readings...
Are you saying are roads are bad!!! I agree, I was even thinking of a SRF04
to warn me if the oncoming speed bump is going to rip the sump off!!!
I've got a few new bits on order so I'll have a play and see what I come up
with.
Cheers
Kev/.
email.me@k... writes:
> with.
A three axis accelerometer and a faster chip like the BS2SX might do the
trick. The SX (not BS2SX) is lightning fast compared to the Stamp, much
cheaper and much more difficult to program than the BS2.....
If you are interested in things like dive during braking, or squat during
acceleration, lean during cornering, etc., it probably isn't necessary to
see a data curve showing momentary readings as much as to see what kind of
peaks you may have had at extreme moments. After all, if the worst reading
doesn't exceed maximum allowable values, no lesser reading will be a danger,
either. And we ALL have bad roads. I mean, if you believe the press (oh,
PLEASE!!), Northern Virginia, in the US, where I live, has one of the
wealthiest roads programs in America. And I dodge one particular, and
growing, pothole daily as I drive down that particular main road. Anyway, I
digress. If, as I say, you only need peaks, even if you need several of
them, a Sample and Hold circuit, with a periodic read routine, would work,
because then the data that is logged would only be the peaks, which are all
you need. And if you wanted those even as fast as one every second, I don't
think that would be beyond the bs2's capabilities. Of course, putting the
Sample and Hold in circuitry is not as much fun, nor maybe as elegant, as
putting it in software, but on the other hand, an peak that passed quickly,
and many, undoubtedly, would happen so quick it would be sheer coincidence
if you even read them, would NEVER show up in your data if the S&H was in
software. After all, if the peak doesn't happen IN your sample window, you
don't have a peak. Sort of like the tree in the forest. You might even feel
the thump at home when it falls, but you still can't prove it made a sound
if you didn't sample for the sound as it occurred.
Sent: Friday, May 09, 2003 5:49 AM
over
> what
SRF04
up
> with.
> Cheers
> Kev/.
