Supplying power and addressing stamps up one wire — Parallax Forums
edited 2003-05-08 04:31 in General Discussion
Hi All,
I have an idea that I want to supply +12 volts up a wire to a group
of lamps that are wired in parallel to it. Each lamp will be
controlled by a basic stamp which is individually addressed to
control it's respective lamp.
Here's the problem - How do I multiplex a data signal up a wire that
is carrying 12VDC?
I have considered DTMF, but need reasonably high speed (need to be
able to address five lamps in say half a second). Another wire just
isn't an option.
Does anybody have any ideas?
Dwain.
    edited 2003-05-04 04:16
    In a message dated 5/3/2003 8:09:41 PM Pacific Daylight Time,
    dwainsworld@e... writes:
    > Hi All,
    > is carrying 12VDC?
    > isn't an option.
    > Regards,
    > Dwain.
    I am not real clear on what you are attempting to do? You have a series a
    lamps wired in parallel. You want the stamp to control several lamps with one
    output wire???
    Please clarify a little/
    edited 2003-05-04 08:11
    > > Hi All,
    group
    that
    > > is carrying 12VDC?
    be
    just
    > > isn't an option.
    > > Regards,
    > > Dwain.
    series a
    lamps with one
    > output wire???
    Sorry, my description wasn't clear.
    Basically I want to send data to stamps up a wire that has a 12VDC
    rail on it, for the purpose of turning lamps on and off. So up one
    wire i want to power a stamp AND send data to it from another stamp.
    The data will tell the receiving stamp what lights to turn on and off.
    It's a multiplexing question - how do I put a +12VDC supply rail AND
    some form of communication between two stamps up just one wire?
    Dwain.
    edited 2003-05-04 14:51
    Will the two stamps share the same ground?
    edited 2003-05-04 19:19
    Hi Dwain,
    I don't think you need to give up on DTMF. The tone bursts can be
    quite short, and 5 could easily fit in 1/2 second. Of course, you
    need a touch tone decoder at the other end in addition to the Stamp.
    The Stamp can generate DTMF but not decode it.
    Alternatively, you could use a cheap LM567 single tone decoder, and
    send a simple ascii codes as tone pulses. The "detect" output from
    the LM567 goes into a stamp pin. The message could be encoded as
    ascii at 2400 baud or as pulse length. That is about 50 milliseconds
    per message, within your 5/second requirement. If you use good
    communications cable, you could get much faster transmission speeds
    at higher tone frequencies.
    Another option would be X-10 protocol, but the while the Stamp has an
    Xout command, it does not have X-in, so you would need a decoder for
    that, too.
    -- Tracy
    >Hi All,
    >is carrying 12VDC?
    >isn't an option.
    >Regards,
    >Dwain.
    Thanks once again all for your help re this, sorry I took so long to reply,
    I have been away.
    Looks like the LM567 is the go, have a few in the post coming my way as we
    speak.
    Dwain.
    Sent: Monday, May 05, 2003 4:19 AM
    Subject: Re: [noparse][[/noparse]basicstamps] Supplying power and addressing stamps up one wire
    > Hi Dwain,
    > that, too.
    > -- Tracy
    > >Hi All,
    > >is carrying 12VDC?
    > >isn't an option.
    > >Regards,
    > >Dwain.
