out of variable on BS2p
Archiver
Hi, how do i deal with this problem,
i know it's not the first time someone ask, but i'm new
thanks
John
thanks
John
Eventually we all run out of variable space as our projects get more bloated.
There are two different things I do when this occurs. I either use some
external eeprom or if this is not an option I will try to make a few of the
variables non committed. As in I will use a few that change to accomodate the
value for that instance.
TEMP_1 VAR BYTE
TEMP_2 VAR BYTE
TEMP_3 VAR BYTE
TEMP_4 VAR BYTE
I'm sure if you analyze your code you will be able to find a way of
implementing some temp variables that can be used for more then one instance.
Hope this helps,
In a message dated 5/2/2003 4:49:53 PM Pacific Daylight Time,
johneck790@s... writes:
> Subj: [noparse][[/noparse]basicstamps] out of variable on BS2p
> Date: 5/2/2003 4:49:53 PM Pacific Daylight Time
> From: <A HREF="mailto:johneck790@s...">johneck790@s...</A>
> Reply-to: <A
HREF="mailto:basicstamps@yahoogroups.com">basicstamps@yahoogroups.com</A>
> To: <A
> Sent from the Internet
> thanks
> John
If constant, you may want to try something suggested to me by the Guru
himself, Jon Williams...
Jon writes:
Since there's not much RAM in the Stamp, I wonder if you know it advance what
your patterns will be....· If this is the case, I would recomend storing your
patterns in EEPROM and use a general-purpose routine to send them out.· I had
a similar problem and Jon suggested storing the data in EEProm Something
like this:
PatternA····· DATA··· %00000000, %00000010, ....
PatternB····· DATA··· %10000000, %01000000, ...
Test:
· eeAddr = PatternA
· GOSBU Show_Leds
· PAUSE 1000
· eeAddr = PatternB
· GOSBU Show_Leds
· END
Show_Leds:
· FOR idx = 0 TO 22
··· READ eeAddr + idx, ledData
··· SHIFTOUT Dpin, Cpin, [noparse][[/noparse]ledData]
· NEXT
· ' latch out if using 74x595
· RETURN
-- Jon Williams
i appreciate your help, i just bought the bs2p plus pack and in it the is an
24LC32 ic in it.
could you give me an example how to used it for my extra variable.
thanks in advance
John
Sent: Friday, May 02, 2003 8:13 PM
Subject: Re: [noparse][[/noparse]basicstamps] out of variable on BS2p
> John,
bloated.
the
the
> TEMP_1 VAR BYTE
> TEMP_2 VAR BYTE
> TEMP_3 VAR BYTE
> TEMP_4 VAR BYTE
instance.
> Hope this helps,
> > From: <A
> > Reply-to: <A
> > To: <A
> > thanks
> > John
to Stamps. Keep in mind that the BASIC Stamp has four variable types (sizes)
-- make sure you don't declare a variable with a size bigger than it needs to
be:
Bit - 1 bit ... 0 to 1
Nib - 4 bits ... 0 to 15
Byte - 8 bits ... 0 to 255
Word - 16 its ... 0 to 65535
Also remember that you can reuse variable space by aliasing -- giving the
same RAM location so your program "reads" nicely. You just have to make sure
that aliased variables aren't used at the same time -- a change in one
affects the other.
-- Jon Williams
-- Parallax
In a message dated 5/2/2003 6:49:40 PM Central Standard Time,
> thanks
> John
Stamps, only ONE time have I every "run out" of variables. As it turned out,
the program had a second mode so I could alias a bunch of vars and reset
everything after that mode ended, which made sense because the mode had to do
with reporgraming the data statements used by the project.
In the BS2 series, all Stamps except the stock BS2 have a Scratchpad RAM area
that can be used to hold data. You can't use it for variable space, per se,
you can use it to store information temporarily and retrieve it later.
Look up PUT and GET in the help file or manual to learn how to use the
Scratchpad RAM.
-- Jon Williams
-- Parallax
In a message dated 5/2/2003 7:37:04 PM Central Standard Time,
> Thanks,
> an
> 24LC32 ic in it.
> thanks in advance
> John
You did it again with your good advice.
I used PUT and GET and with 3 extra BYTE var i save 9 WORD var
space...great!!!!!
my robot program used 56% of the internal EEPROM and it's not finish.
now i got to find what to do with my external EEPROM.
anybody got any ideas...
John
ps: keep up the good work
Sent: Friday, May 02, 2003 8:46 PM
> Again, check your program design. In over nine years of working with
BASIC
out,
do
area
se,
> Scratchpad RAM.
> -- Jon Williams
> -- Parallax
> > Thanks,
is
> > an
> > 24LC32 ic in it.
> > thanks in advance
> > John
both RAM and EEPROMs are available and very easy to use. You get a
double-whammy with the PCF8583 in that it's a real-time-clock with 240 extra
bytes of RAM.
The I2C buss has become one of my personal technology favorites lately. It's
very easy to use (even with a stock BS2), and there are thousands of devices
available -- many that will probably serve your robotics project well.
-- Jon Williams
-- Parallax
In a message dated 5/9/2003 2:10:19 AM Central Standard Time,
> Thanks Jon,
> space...great!!!!!
> John
