RF to Serial servo controller
Is it possible to hook up an RF reciever directly to the input of a SSC or do
I need a stamp to receive the data first then pass it on to the SSC ?
Stuart
Stuart
Sent: Thursday, May 01, 2003 12:29 PM
Subject: [noparse][[/noparse]basicstamps] RF to Serial servo controller
> Hi,
> Stuart
You definitely can connect an RF receivers output directly to the Mini SSC II
for remote servo control. Just send data inverted since the SSC-II expects it
inverted.
It's a little more stable if you have a Stamp screening the incoming data, but
not
absolutely necessary. The Stamp can sort through any noise or junk before
sending
servo control data to the SSC-II. Direct, you may see unexpected servo movements
on occasion due to noise pulses.
You can remotely control the SSC-II with IR as well.
-Bruce
tech@r...
http://www.rentron.com
Regards
Stuart
