Simple Motor Control
What's a simple way to get my BS2 to control an 12v DC motor of
about 1.5A at stall? I would like to isolate the BS2 signal to
protect it. There's got to be a quick simple way to do this..
Chuck
Chuck
directions takes an H-Bridge arrangement.
From: chuck_6730 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=71vHx5ZaCJHLGhUsA6aW2jvH28N8q71BoVCuL0CeMmF1PRSrZmqlU2_YIIprtlAi8E962ReqP5TZ1V-MEVxe]chuck_6730@y...[/url
Sent: Thursday, May 01, 2003 9:08 AM
Subject: [noparse][[/noparse]basicstamps] Simple Motor Control
Chuck
http://www.geocities.com/jimforkin2003/
From: Sadler Porter [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=RKkQTQFXdD98NVfCjT3nYtVot5fWBaHE2MtDpMSFcQQ9e8HC3JD_hFq5yWwMxEg1oXeQDsGLQyam0rI_QrEZ]porter.sadler@s...[/url
Sent: Thursday, May 01, 2003 9:49 AM
Subject: RE: [noparse][[/noparse]basicstamps] Simple Motor Control
One direction or two. One direction can be done with a transistor. Two
From: chuck_6730 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=qpOR3NLUw0cdLR49IsxjuEjZ3WzSrnO_kIiCgfITYwu-WtdN4YEGmzL2-J7jVAGQFt1Nb9j2XI_Dpdd2Ik3n]chuck_6730@y...[/url
Chuck
> an 12v DC motor of about 1.5A at stall?
ChuckSadler Porter wrote:
> One direction or two[noparse][[/noparse]?]
> Two directions takes an H-Bridge arrangement.
Actually, you can do both directions with
only two transistors and a DPDT reversing relay
(plus a kickback diode for the relay). <grin>
One transistor is the current sink for the motor,
and the other runs the motor reversing relay.
The advantage is that you only need ONE high powered
MOSFET (and heatsink) for running even a serious
current motor. The relay just needs any old cheap
NPN transistor that's just good enough to trip it.
The relay CONTACTS need to take the motor current,
which is easy.
My question though: Do you only want on/off control,
or proportional speed?
With either an H-bridge design or the above circuit,
to control your speed you'll need to use PULSOUT
commands to modulate the MOSFET (or transistors).
The problem with using PULSOUT comes in multimotor
applications. Your program is stuck and ignoring
the world while it is busy generating the PWM pulse
for one motor. That's why you see so many EXTERNAL
"multichannel motor controller" products out there
for Stamps to use. They unload the BS2 from that task.
> way to do this..
Use an optoisolator between the BS2 outputs and
the transistors. You can get quad optos in
a single pack from Digikey to run an H-bridge.
- Keith Mc.
"It's not an optical illusion... It just looks like one..."
with a 2n222 to switch directions and a TIP120 transistor to PWM the motor.
> which is easy.
> > way to do this..
From: Keith Mc. [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=twNlSBo79-6Chl8FD6OwWnhCp4jG5LtTsZvr4HileJRqcQiq3wV1HbgL494DffXN3maWgFEdOxaQ]acti@P...[/url
Sent: Thursday, May 15, 2003 11:27 PM
Subject: [noparse][[/noparse]basicstamps] RE: Simple Motor Control
which is easy.
> way to do this..
- Keith Mc.
