decimal to acsii string for LCD
Hello,
I'm trying to get the temp inputs from my DS1620 temp chip to display
on my parallel 2x16 LCD screen. Using DEBUG's SDEC or DEC command
allowed me to echo the temp out the serial line to my terminal window
but that's not want I'm tring to do. Somehow I have to break up the
16-bit word into seperate ASCII char's(up to 3 char's, like "-10"
or "104" ) so I can pulse them out to my LCD. I'm in 4 bit mode BTW
so far this is all I have.
char = TempF.LOWBYTE ' this loads char with the current temp stored
in the lower byte of TempF(WORD VAR)
so now I have a decimal number stored in a variable, and need to get
it on my LCD
any ideas? or maybe someones had this problem and has a subroutine?
only thing I've come up with is to use serialin and serialout
functions(DEC) using 2 pins and then take the in data and out it to
the LCD. (sounds CPU intensive and probly the incorrect way to do it,
must be some math routine.)
also,
Should I just buy a serial LCD? and use serialout with its built in
data formatter? the main reason I don't want to is I bought the
complete stampworks package and would kinda like to use what I have.
Also parallel LCD's are more in my price range also. If anyone can
help please respond ASAP. I'd really like to contine my project.
Thank you very much,
Sean T. Pinkerton
it on my LCD
also,
Sean T. Pinkerton
ASCII) to send the value to the display. This will work for values less than
1000:
Print_Digit:
FOR idx = 2 TO 0
char = (myNumber DIG idx) + "0"
GOSUB LCD_Write
NEXT
-- Jon Williams
-- Parallax
In a message dated 4/28/2003 9:30:11 PM Central Standard Time,
mpink2002@y... writes:
> Hello,
> it on my LCD
> also,
> Sean T. Pinkerton
