2P serin to scratchpad - Buffer?
Ok so scratch the scratchpad idea, I need the full message plus the checksum,
and it might be days before a second message dislodges
the first.
Anyone know of a serial buffer that can read say 128 or so bytes, then let me
parse it in one byte at a time looking for the
<CR><ETX>checksum<CR>
> Yes, it is required.
> I have used it with GPS where, as you indicate, the length of the incoming
> string varies. That said, the $GPMRC string is followed by another so I set
> my \L parameter to get the entire $GPMRC string plus a few possible extra
> bytes of the next string. If you don't need the entire string, you can
> shorten the \L parameter to accept the number of bytes you want to examine.
> -- Jon Williams
> -- Parallax
> In a message dated 4/28/2003 12:42:58 PM Central Standard Time,
> techsupport@f... writes:
> > Tnx and one further question, is the /L modifier needed.
> > In this application the length of the string varies, the end of the string
> > is denoted by a <CR><ETX> followed by the checksum and a
> > <CR>.
> > How would SPSTR be implemented knowing that:
> > 1. the length of the string varies.
> > 2. the end marker occurs between the end of the string and the checksum<CR>
> [noparse][[/noparse]Non-text portions of this message have been removed]
the first.
> -- Jon Williams
> -- Parallax
> > <CR>.
http://groups.yahoo.com/group/basicstamps/files
for a $10 roll-your-own solution. Has worked well for many including
me. Up to 1280 bytes of serial buffer you can read out at your
leisure.
Steve
On 28 Apr 03 at 13:10, FalconWireless Tech Support - wrote:
> ...Anyone know of a serial buffer that can read say 128 or so
> bytes, then let me parse it in one byte at a time looking for the
> <CR><ETX>checksum<CR> ?
