Turn on a led for two minutes each 13 minutes all day long...
Archiver
This would be my guidance. If time-of-day isn't required by the project, I
would simply reset the clock to midnight at the beginning of each cycle, then
check the time in my main loop. In this manner, the LED control becomes a
"background" process since the timing is handled by the RTC.
-- Jon Williams
-- Parallax
In a message dated 4/27/2003 9:32:00 AM Central Standard Time, leroy@f...
writes:
> What about using a clock chip? you would just need to see if the time has
> passed, and if so process the logic??
-- Jon Williams
-- Parallax
writes:
I
then
has
monitor the alarm output of the chip. It may be easier just to look at the
time values coming back, especially if not using the RTC for time-of-day.
-- Jon Williams
-- Parallax
In a message dated 4/27/2003 10:52:11 AM Central Standard Time,
daweasel@s... writes:
> I thought the RTC chips had an alarm feature as well?
timer for reminding me to do radio checks for a neighborhood patrol group I
belong to. I used one of the timer / counters and a 32,767 xtal, tied to a
BS1 and one of the crappy serial LCD's. Worked pretty well and I would take
it down to the radio room when it was my turn to work there.
Since it was rather unusual looking and had a count-down display, I decided
leaving it unattended down at the police office would be bad. However, it
got left behind one night and the other operators latched onto it and told
me I needed to leave it there more often. Now I have to clean it up and make
it run off a wall-wart. Since I have a spare DS1302 I may use it also, so I
can do the date and time.
> Yes, most do. Using this feature would, however, require another input to
the
doesn't help much with the BS2, which has no interrupt
inputs.
One approach would be to set up a DS1302 time chip,
'sleep' the BS2 for some period, then on wake up ask
the time chip what time it REALLY is, and cycle on
that until the desired time occurs.
project,
> I
cycle,
> then
becomes a
the time
> has
