upload from BOE-Bot to StampBASIC
Hello all,
Totally new to StampBASIC here. Download and installed StampBASIC
v1.33. Have the BOE-Bot BS2 (the one with the StampInClass logo on
the board). How do I upload whatever is in the BOE-BOT into
StampBASIC?
Thanks.
StampBASIC?
Thanks.
| Hello all,
| StampBASIC?
Well, it depends on what you want to upload... You can't upload the program
stored in the Stamp's EEPROM (OK, you can, but based on what you've said,
you don't want to try [noparse][[/noparse]it involves advanced equipment, and stuff I don't
even fully understand or want to address: electron microscope, anyone?]).
You can upload data you have stored or had the Stamp store in the EEPROM,
but only if you've provided for such uploading in the program you've loaded
in the Stamp.
If you simply want to send data from the Stamp to the Stamp Editor on your
computer, try using the DEBUG instruction (well documented in the
instruction listing in the Stamp manual and the Help file that comes with
your Stamp Editor).
Comprende? :O)
Let me answer your question a little more simply.... NO, YOU CAN'T.... OK, I
just wanted to make sure my point was clear...
TTYL,
- Robert
<uavscience@f...> wrote:
> From: "crazycowpie1" <lostpatrol@e...>
> | Hello all,
StampBASIC
on
> | StampBASIC?
the program
you've said,
don't
anyone?]).
EEPROM,
you've loaded
> in the Stamp.
on your
comes with
> your Stamp Editor).
> Comprende? :O)
CAN'T.... OK, I
> TTYL,
> - Robert
Robert: That is what I want...display what is on the BOE-BOT to the
debug editor. I will look at the debug command..but if you know off
hand how to do it, I would be appreciated very much if you can show
me the command.
Thanks again
| debug editor.
Well, that still doesn't really answer my question... Do you want to display
the stored program? If so, this is impossible (or at least not feasible). If
you want to display data you have written to the Stamp's EEPROM, this is
possible with a READ instruction followed by a DEBUG
| me the command.
Sure, here's the simplest version...
Stuff var byte
DEBUG Stuff ' Stuff is the data to be sent
rest of code...
"Stuff" (whatever it contains) will be displayed in ASCII format in a debug
window on your computer. A number of modifiers such as DEC, BIN, and HEX are
available, as detailed in the Stamp Manual and in the PBasic instruction
listing in the Stamp Editor help file.
- Robert
