Serial communication between Java and BS2sx
Archiver
I'm trying to send data from a BS2SX to a Java program
running on Windows 98 (also tried on a ME machine)
that uses the javax.comm APIs to listen to the serial
port. I seem to be able to open the port without
problems, but the problem is that I never receive any
data from the BS2SX.
The command I use to send data from the BS2SX is:
SEROUT 16, 16624, [noparse][[/noparse]STR resout\6]
where resout is a 6 byte array.
The program that I use to read data is the SimpleRead
example that is included in the Java Communications
API package with the following serial port
parameters:
serialPort.setSerialPortParams(9600,
SerialPort.DATABITS_8,
SerialPort.STOPBITS_1,
SerialPort.PARITY_NONE);
Has anyone else run into this problem? Should I perhaps
go ask in the javelinstamp forums as well?
I've been banging my head against this problem all day
and would really appreciate a solution.
William
parameters:
William
Stamp parameters are correct by sending a test string in a loop that you can
watch on your PC using a known-working terminal program. Once you know that
the Stamp is sending what you want at the baud-rate you desire, then you can
start working on your Java program.
Just keep in mind that if you send something from the PC to the Stamp via the
programming port (pin 16), the Stamp will echo it back so your PC program
must be prepared to deal with this.
-- Jon Williams
-- Parallax
In a message dated 4/26/2003 1:30:39 PM Central Standard Time,
william@s... writes:
> Hi,
> parameters:
> William
> You can make sure the Stamp parameters are correct by sending a test
> string in a loop that you can watch on your PC using a known-working
> terminal program.
Well, the Basic Stamp Editor's debug window receives everything that
the Basic Stamp generates and sends just fine, but the Windows
HyperTerminal doesn't show anything when I connect it directly to the
same com port with the same baud rate, stop bits, parity and without
flow control.
> Stamp via the programming port (pin 16), the Stamp will echo it
> back so your PC program must be prepared to deal with this.
My app never needs to send anything to the BS2SX so this is not really
a problem. However, when I do make my app or HyperTerminal send
something to the BS2SX for testing purposes, I receive echos from that
transmission in both applications (as well as in another terminal
application that I have tried). I just don't receive the data that
the Basic Stamp itself generates and sends, that data only appears in
the Basic Stamp Editor's debug window.
Thanks for answering.
William
the only programming board that does not have the DTR flag
connected to ground so I had to manually set it low using
software to get it to work. I'm currently using the BS2
Carrier Board, but I had only used the BOE in the past.
