Saving RAM space.
In anticipation of a new NMEA RS232 GPS box I have
ordered, I started whipping up some code for it (after
looking at a few examples), however I have run into
major problem; I need more RAM space.
The code I have just about gobbles up all my RAM, and
I need more space so I can perform calculations on the
NMEA data received.
I’m relatively new to Stamps (though I've had it a
while), and am wondering if anyone can give me a few
pointers on how I could save some space (or possibly
add some more ram to my BS2sx?).
Here’s the code anyway.
'{$STAMP BS2sx}
'{$PBASIC 2.0}
'Liam Farr - liam@f... - 24/04/03
Variables
time var byte(6) 'time UTC (HHMMSS)
lat var byte(8) 'latitude without last decimal
long var byte(9) 'longitude without last decimal
Main Code
nmea_in: 'get the current time, lattitude and
longatude from the serial nmea input.
serin 2, 16884, [noparse][[/noparse]wait("$GPGGA"),skip 1,str time\6,skip
1,str lat\8,skip 3,str long\9] '16572 = 4800 Baud-8
Bit No parity Inverted for BS2 & BS2e, 16884 = 4800
Baud-8 Bit No parity Inverted for BS2SX & BS2p.
goto nmea_out
nmea_out 'output the nmea data (time, lat & long)
to the debug window.
debug "Time: ", DEC time, " ", "Latitude: ", DEC
lat, " ", "Longitude: ", DEC long, CR, CR
goto nmea_in
Cheers
Liam
__________________________________________________
Yahoo! Plus
For a better Internet experience
http://www.yahoo.co.uk/btoffer
NMEA data received.
'{$STAMP BS2sx}
'{$PBASIC 2.0}
Variables
Main Code
goto nmea_out
goto nmea_in
Cheers
Liam
Yahoo! Plus
Volts magazine last year. Even thought I use a BS2p for GPS (so that the
entire GPMRC string can be buffered to the Scratchpad RAM), the conversion of
of string data to useful numbers may be useful to you.
Go to this link (Parallax -> Resources -> Nuts & Volts Columns -> Volume 3):
<A
HREF="http://www.parallax.com/html_pages/resources/nvcolumns/Nuts_Volts_Download\
s_V3.asp">
http://www.parallax.com/html_pages/resources/nvcolumns/Nuts_Volts_Downloads_V3.
asp</A>
and download article #83.
-- Jon Williams
-- Parallax
In a message dated 4/26/2003 3:50:30 AM Central Standard Time,
nz_liam@y... writes:
> Hi,
> NMEA data received.
> I
Cheers
Liam
--- jonwms@a... wrote: > You might want to look at
my article on GPS
> reception and decoding from Nuts &
> you.
> <A
s_V3.asp">
> asp</A>
> -- Jon Williams
> -- Parallax
> Standard Time,
> > Hi,
> (after
> into
> and
> the
> > NMEA data received.
> > I
