Another Servo Voltage Question
I asked one a few weeks ago, and thanks to everyone who responded. I
have 2 servos hooked up to a BoE, which supplies the unregulated
battery voltage to the servos. I'm using the 2 servos to move the
robot and I was curious if different changes in voltage would have an
effect on the distance the servo travels. For instance, here is some code:
uturn:
for x = 0 to 330
pulsout 12, 1700
pulsout 13, 1680
next
return
At the moment it makes a u-turn. However, the batteries will slowly
drain. So will that code make a u-turn for my robot at 6.5volts and at
6.0 volts? Thanks!
uturn:
for x = 0 to 330
pulsout 12, 1700
pulsout 13, 1680
next
return
6.0 volts? Thanks!
a certain distance over the life of the batteries.
Your options include:
Wheel encoders
Monitoring the battery voltage and working up a table of values at
various voltages
Turning based on other input (wall sensors, external encoder, etc...)
> uturn:
> for x = 0 to 330
> pulsout 12, 1700
> pulsout 13, 1680
> next
> return
> 6.0 volts?
voltage available which is higher than what the servos
require say 12 volts then use a 7805 regulator (5
volts) to supply power to the servos.At least you
would always be working with the same voltage instead
of having a drop when one servo is running then trying
to figure the voltage available for the other servo.
Sorry I didn't read previous posts about this.
> who responded. I
> unregulated
> servos to move the
> uturn:
> for x = 0 to 330
> pulsout 12, 1700
> pulsout 13, 1680
> next
> return
> at 6.5volts and at
> 6.0 volts? Thanks!
> from the same email address that you subscribed.
> Text in the Subject and Body of the message will be
> ignored.
__________________________________________________
Do you Yahoo!?
The New Yahoo! Search - Faster. Easier. Bingo
http://search.yahoo.com
