Vin for BS2-IC
I'm building a unit using the BS2-IC. The unit will have a +/- 18 volt supply.
Is this voltage ok to apply to the Vin of the BS2-IC or should I put a regulator
in the circuit to reduce the voltage?Larry KB0BMP
Do you Yahoo!?
The New Yahoo! Search - Faster. Easier. Bingo.
Do you Yahoo!?
it to work. 18 will damage the BS2. Jacob
larry vandyke <kb0bmp@y...> wrote:I'm building a unit using the BS2-IC. The
unit will have a +/- 18 volt supply. Is this voltage ok to apply to the Vin of
the BS2-IC or should I put a regulator in the circuit to reduce the
Do you Yahoo!?
from the same email address that you subscribed. Text in the Subject and Body of
the message will be ignored.
Do you Yahoo!?
