Hex Ser Some Question
Dear All
Thanks for your replies. I have some more question, your replies would really be
valuable for me.
The stamp I am using gets data from one camera(input camera) and has to transmit
the information to another(output camera) after certain calculations.
Now I have conected the Input camera and it works perfectly.My question is can I
used the same serial port(#16) which I use for downloading the program in the
stamp for transmitting data to the Output camera.
I mean after downlading the program intot he stamp I disconnect the serial port
from the PC and connect it to the Output camera
Is this possible
Thanks Once again
waiting eargerly for your reply
Jimmy
Allan Lane <allan.lane@h...> wrote:Yes, this should work as you
intend.
Note 'Hex' may confuse some people. If you
use: SEROUT
, , [noparse][[/noparse]HEX ] then
converted to one or more hex characters
will be output.
If you just output [noparse][[/noparse] $ff ], then the one byte
containing $ff will be output, which I believe
is what you intend.
--- In basicstamps@yahoogroups.com, "jimmy_prett"
wrote:
> Dear All
> I am tryin to get RS 232 signals from the BS2 SX.The stamp will
send
> hexadecimal signals(7 byte size) of the form "FF 01 00 04 20 00 25"
> Can I use the serial port avaiable with education board for this.Do
> have to make any special connections??
> Also will this code work(I mean is it ok if I send the hex message
> like this)
> SerString Var Byte(7)
> SerString(0)=$FF
> SerString(1)=$01
> SerString(2)=$00
> SerString(3)=$04
> SerString(4)=$20
> SerString(5)=$00
> SerString(6)=$25
> SEROUT 16, 240, [noparse][[/noparse]STR SerString\7]
> I would be really grateful if any of you could help me
> Best
> Jimmy
from the same email address that you subscribed. Text in the Subject and Body of
the message will be ignored.
Do you Yahoo!?
The New Yahoo! Search - Faster. Easier. Bingo.
valuable for me.
Is this possible
Thanks Once again
Jimmy
intend.
use: SEROUT
will be output.
is what you intend.
wrote:
> Dear All
send
> like this)
> SerString(0)=$FF
> SerString(1)=$01
> SerString(2)=$00
> SerString(3)=$04
> SerString(4)=$20
> SerString(5)=$00
> SerString(6)=$25
> Best
> Jimmy
Do you Yahoo!?
port to the 'output' camera.
Some caveats, though.
The BS2 serial port uses the attached device's
TX line to provide voltage for its RX-Out
transistor. (BS2 drives the DB-9 Rx pin,
so you can use a straight through cable).
As long as the camera you attach the
cable to is driving its TX line, this should
work. Of course, you have to match baud
rates and modes (when using BS2 built-in
serial, you need to select 'Inverted' mode)
Note also that the BS2 is a single-threaded
beast -- so it can't 'listen' to one port
while transmitting on the other. You may
have to do something to guarantee that
the 'input camera' does not talk while the
BS2 is talking to the 'output camera'.
--- In basicstamps@yahoogroups.com, JIMMY GILL <jimmy_prett@y...>
wrote:
> Dear All
would really be valuable for me.
has to transmit the information to another(output camera) after
question is can I used the same serial port(#16) which I use for
downloading the program in the stamp for transmitting data to the
Output camera.
serial port from the PC and connect it to the Output camera
> Is this possible
> Thanks Once again
> Jimmy
intend.
> use: SEROUT
> will be output.
> is what you intend.
> wrote:
> > Dear All
> send
25"
this.Do
message
> > like this)
> > SerString(0)=$FF
> > SerString(1)=$01
> > SerString(2)=$00
> > SerString(3)=$04
> > SerString(4)=$20
> > SerString(5)=$00
> > SerString(6)=$25
> > Best
> > Jimmy
Subject and Body of the message will be ignored.
> Do you Yahoo!?
