BS2 general questions — Parallax Forums
edited 2003-04-23 16:22 in General Discussion
hi, i've never used a BS2 before...
i need it to process information from another microprocessor. how can i get
that information (sent over a serial link) into the RAM so it can be processed?
Can i even use the serial bits for that purpose? or would i have to use the I/O
pins (which I don't think I can because they're already used)?
    edited 2003-04-23 08:06
    --- In basicstamps@yahoogroups.com, "ckkim_1999" <ckkim_1999@y...>
    can i get that information (sent over a serial link) into the RAM so
    it can be processed? Can i even use the serial bits for that
    purpose? or would i have to use the I/O pins (which I don't think I
    Well, the short answer is you can use the stamp's programming port
    (Rx/Tx) to read information from a second microprocessor.
    However, it depends on several issues: is the data from the micro
    fixed length or variable length, how much data do you have per
    message, is it unidirectional or bidirectional, what about speed?
    The stamp's programming port can be used with asynchronous serial
    comm only, but it may be preferable to do synchronous serial comm
    in your case (using two IO pins, one for data, one for clock).
    To find a solution you need to be more specific about your actual
    hardware and software requirements.
    regards
    adrian
    edited 2003-04-23 14:23
    Don't forget that you can use any of the pins as I/O and pick one or more as
    serial data ports. You don't have to use the programming port for the
    serial I/O other than when programming the stamp. For an example, check out
    my web site which shows using P2 as a serial input that accepts serial data
    from a pc or pocket pc. The stamp then controls mechanical devices.
    Jim
    http://www.geocities.com/jimforkin2003/
    From: ckkim_1999 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=m8TvFOBzyryMe97mCTrIuq_tew1nmfAD0GIAy99QvFWiX4zD_UfnuWXu4SH82d2gb1IHEc_LPfydGODm4g]ckkim_1999@y...[/url
    Sent: Wednesday, April 23, 2003 2:08 AM
    Subject: [noparse][[/noparse]basicstamps] BS2 general questions
    processed? Can i even use the serial bits for that purpose? or would i
    have to use the I/O pins (which I don't think I can because they're already
    used)?
    Very true, but you will need a 232 driver
    (like max232) if you want to 'talk' out
    a BS2 pin.
    Note the BS2 will work as a 232 receiver
    if you merely put a 20 Kohm
    resistor between the pin and the 232 port.
    Its internal protection diode will clip the
    negative going part of the signal to
    the BS2.
    or more as
    the
    check out
    serial data
    > Jim
    > From: ckkim_1999 [noparse][[/noparse]mailto:ckkim_1999@y...]
    can i get
    would i
    already
    > used)?
    Subject and
