accelerometer issues and questions (Parallax/Memsic devices) — Parallax Forums
edited 2003-04-24 21:49 in General Discussion
I have been experimenting withe the Memsic 2125 accelerometer Demo kit from
Parallax and have noticed some quirks.
1.) The demo in the 2003 catalog uses a divisor of 16 supposedly to scale the
xmG and ymG values so that the ATN function will work. (it only works for
byte size variables ...not word size). But the example in the app note that
is shipped with the demo kit uses a divisor of 8. Why the difference? Which
is better or would it be better to develop a 16 bit ATN function? Would this
improve the accurracy or address the issue in part 2 below (certain angles
produce screwy results)?
2.) I am using the code for sensing 0-360 degrees of rotation, but the value
"blows up" in certain positions (especially around +/- 90 degress or so. Does
anyone know why this happens? Otherwise the ouput is fairly accurate and
repeatable.
Does anyone have experience with this type of device? Any help, suggestions,
or answers to my questions would be appreciated. Thanks!
    edited 2003-04-23 23:41
    I think what you're describing as a "blowing up" of data in certain
    positions comes from the nature of the sensor. I'm not familiar with this
    particular sensor, but in general the piezoelectric material on each axis is
    most sensitive parallel to the horizon. Because of this, the resolution
    declines and the change per degree of tilt goes from a negligible amount to
    more than 10 times what it was per degree of tilt at +/- 1 g. You may want
    to check the data sheet and adjust the raw data output accordingly. I'm not
    quite sure about the ATN divisor you're talking about, but certainly 16 bit
    resolution would help..i've been using 12-16 bit ADC's
    >From: azeasi@a...
    >Reply-To: basicstamps@yahoogroups.com
    >Subject: [noparse][[/noparse]basicstamps] Re: accelerometer issues and questions
    >Date: Tue, 22 Apr 2003 15:40:04 EDT
    >the
    >this
    >value
    >Does
    >repeatable.
    >suggestions,
    >from the same email address that you subscribed. Text in the Subject and
    >Body of the message will be ignored.
    >Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
    _________________________________________________________________
    STOP MORE SPAM with the new MSN 8 and get 2 months FREE*
    http://join.msn.com/?page=features/junkmail
    edited 2003-04-24 06:40
    This may be saying the same thing a different way as Christian said it,
    but tilt measurements with accelerometers are based on the cosine of the
    angle of tilt with respect to the horizon. The cosine function shows
    the greatest change per degree near 0 degrees, and the least near 90
    degrees. This is true for all accelerometers, not just those based on
    piezoelectric material, i.e., it's the physics of gravitational
    components, not the sensor material.
    Dennis
    From: Christian Wentz [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=XmwMqO9bsFii3THmTbsFxq_NmMNNerI6CEfMypwhpw8rAB3hGwbvl7_sMvuVrBmPdNHDJPLxAN31qg]cwentz86@h...[/url
    Sent: Wednesday, April 23, 2003 3:41 PM
    Subject: Re: [noparse][[/noparse]basicstamps] Re: accelerometer issues and questions
    this
    axis is
    to
    want
    not
    bit
    >From: azeasi@a...
    >from Parallax and have noticed some quirks.
    >scale
    >the
    for
    that
    Which
    >this
    angles
    >value
    so.
    >Does
    and
    >repeatable.
    >suggestions,
    True, i suppose i didn't word that one the greatest-thanks for the
    clarification.
    Christian
    >From: "Dennis O'Leary" <doleary@e...>
    >To: <basicstamps@yahoogroups.com>
    >Subject: RE: [noparse][[/noparse]basicstamps] Re: accelerometer issues and questions
    >Date: Wed, 23 Apr 2003 22:40:42 -0700
    >Dennis
    >From: Christian Wentz [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=2boSTdzo49vccvCYL7r7pjxs-1jqAYdPYOfvrvWKo2kT__gOh4bZQVlxFhCloGwIA3CZVDUL_ZEEViCSzVHs]cwentz86@h...[/url
    >this
    >axis is
    >to
    >want
    >not
    >bit
    > >From: azeasi@a...
    > >scale
    > >the
    >for
    >that
    >Which
    > >this
    >angles
    > >value
    >so.
    > >Does
    >and
    > >repeatable.
    > >suggestions,
    Help STOP SPAM with the new MSN 8 and get 2 months FREE*
