Fluctuating RC readings
I have a project which involves using a remote controller to control
a platform. The direct pulse-in readings of the basic stamp from the
receiver give very fluctuating values even when the remote
controller lever stick is stationary. I can overcome this problem
using software programming, but I sacrifice resloution. Like to ask
to there is a good solution using hardware to filter off the noise
or other disturbance. I have tried using a simple RC noise filter
but did not really help.
Thank you!
Thank you!
I had the exact same problem trying to use pulsin to get the 20ms
commands from my R/C receiver, no one on here gave me an answer that
worked, so if you figure it out could you pass on the knowledge please?
-Mike
From: juijing [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=hZqkJdBzDmXtt1T6nBx4k97sxjrZHeKAFTdBrDFTj4s1Qlc1Ft3x8zSSNerdqFjQRm7oDS1KW2PniXqy]juijing@y...[/url
Sent: Tuesday, April 22, 2003 1:27 AM
Subject: [noparse][[/noparse]basicstamps] Fluctuating RC readings
Thank you!
Your use of Yahoo! Groups is subject to
program with a tolerance range that is greater than the fluctuating range. If
the pulse-in value is within this range, it means that the remote controller
lever stick is stationary and I will use the same previous pulse-in value for
calculation.Hence, my servos will not be jerky. However, I loses resolution due
to this "buffer" zone. I am quite sure there is a hardware solution to this
problem. So, if anyone knows, pls help. Thanks in advance!
Mike Dillon <laxboy687@e...> wrote:Hey,
-Mike
From: juijing [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=gADOi1PdSdEpuMO_OwSgJX_qHCdI4M3-kXlNRyUHlU0RUvoXjZq2jMqGMHdcokKvZ2z62T8O1Wl0eQ]juijing@y...[/url
Thank you!
from the same email address that you subscribed. Text in the Subject and Body of
Do you Yahoo!?
The New Yahoo! Search - Faster. Easier. Bingo.
that the wiring is picking up electrical noise that makes your PULSIN
or RCtime readings erratic. Consider using a shielded twisted pair
from the Stamp to the controller.
In software, a digital lowpass filter or a boxcar average might help.
-- Tracy
For filtering,
>Hi, I overcame the problem using programming.I create a "buffer"
>zone in the program with a tolerance range that is greater than the
>fluctuating range. If the pulse-in value is within this range, it
>means that the remote controller lever stick is stationary and I
>will use the same previous pulse-in value for calculation.Hence, my
>servos will not be jerky. However, I loses resolution due to this
>-Mike
>From: juijing [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=VobU6_Gm1i9XvCBDxZOVXbOqf410HPYua0UMb5TxnLNaUxnIgcNgw417R0ojIttIQwfDOPNP3GUZDR94]juijing@y...[/url
>Thank you!
>Do you Yahoo!?
>Subject and Body of the message will be ignored.
16-point sliding boxcar average of A/D data at the PIC level, before
uploading the data to a PC through a serial port. Another tip for
low-noise A/D data is to sample at a higher rate (I use 5X) than your
system requires, perform the above boxcar averaging (which is a low-pass
filter), and then send decimated data (such as every 5th point) to the
PC for final analysis.
Dennis
From: Tracy Allen [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=3TIpOAd8a-hRPh6g12n3MlAr9T5TAjRG9k3gjrRjV7DMRkHI6ENFr3GRBjfWjJihIzz5oKsQuR04dARd]tracy@e...[/url
Sent: Wednesday, April 23, 2003 10:45 AM
Subject: RE: [noparse][[/noparse]basicstamps] Fluctuating RC readings
How far away from the Stamp is your remote controller? It may be
-- Tracy
For filtering,
>-Mike
Dennis O'Leary <doleary@e...> wrote:Tracy's suggestion is right on the
mark, as usual. I like to do a
Dennis
From: Tracy Allen [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=PR2KpkAkjVGVhy5ZiZjp6wOlpsZmVlIXvqHdaCNPsJ3jay8wfA7GIatlO8Su7EF_S7uq0aG61uX-uA]tracy@e...[/url
-- Tracy
For filtering,
>Mike Dillon wrote:Hey,
>-Mike
Do you Yahoo!?
1) Every output reading is the average the the past N raw readings.
Say, N=16. "Boxcar" means that all 16 readings carry equal weight,
kind of like the profile of a boxcar on a train. Alternative schemes
give less weight to readings further in the past. "Sliding" or
"moving" means the average is always the past 16, and output readings
can be had at the same rate as input readings. That is opposed to a
fixed average where you might accumulate 16 raw samples, then output
the average of those, and then take 16 more and output the average of
those, in which case the output rate is 1/16 of the input rate.
2) To initiate a boxcar average, you take one raw reading and fill 16
slots in a buffer with that same reading. The sum is just 16*(raw
reading). You maintain the sum also in a separate memory location.
You see, the boxcar is fairly memory intensive, so you probably need
to use a Stamp with scratchpad RAM.
3) Each time you take a new raw reading, you put it in the top of the
buffer, and drop the oldest reading from the bottom of the buffer.
You subtract the oldest reading from the sum and add the newest
reading. The output value is the sum divided by 16. The top and
bottom of the buffer are usually determined by a pointer, rather than
by actually moving the data.
An exponential lowpass filter is less memory intensive:
1) Every new output reading, X, is made by taking the old value of X
times (N-1)/N, plus the new raw reading times 1/N. By making N
larger, each new reading contributes less to the total, the effect of
old readings takes longer to "fade away". In the Stamp, there are
some tricks necessary to maintain accuracy with integer math. I have
some info about that on my web site.
The time constant in either of these schemes is in terms of number of
samples, not time. To link it to time, you have to consider how
often you take the samples.
-- best regards
Thomas Tracy Allen PhD
http://www.emesystems.com
mailto:tracy@e...
>Can you elaborate more on "a boxcar average" ? Thanks!
>right on the mark, as usual. I like to do a
>Dennis
>From: Tracy Allen [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=7aG804eQed_QSzgyICiI443HgkurBas-aXpEYsosYM40k-utLTP1XEAQRg2lQ6_VwuLO5hIoxp6nRg]tracy@e...[/url
>-- Tracy
>For filtering,
>>-Mike
of N=16 is arbitrary. As a larger N is used, the data are filtered at a
lower frequency, which may or may not be a good thing for a particular
application. Older digital signal processing literature referred to
these as "smoothing filters" for obvious reasons. A choice of N as a
power of 2 simplifies the averaging process for Stamp use, by shifting N
bits to the right in a cumulative sum, as explained on Tracy's website.
Dennis
From: Tracy Allen [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=4LsRybcF47vTi_tV-EyUwxYtgdZGEaTkLkzRv9tEtvhr2CkeqchGYJ5WGSbKsGD7qOSrkd4z5JhIKQ]tracy@e...[/url
Sent: Thursday, April 24, 2003 10:25 AM
A sliding boxcar average:
-- best regards
mailto:tracy@e...
low-pass
>Dennis
>How far away from the Stamp is your remote controller? It may be that
>the wiring is picking up electrical noise that makes your PULSIN or
>RCtime readings erratic. Consider using a shielded twisted pair from
>-- Tracy
>For filtering,
>>Hi, I overcame the problem using programming.I create a "buffer" zone
>>means that the remote controller lever stick is stationary and I will
>>use the same previous pulse-in value for calculation.Hence, my servos
>>will not be jerky. However, I loses resolution due to this "buffer"
>>zone. I am quite sure there is a hardware solution to this problem.
>>please?
>>-Mike
