Strange bug in LOOKUP !!!!
Hi
Pls see the following code : There seems to be a
strange bug in the LOOKUP command. Or theres something
strange i am doing. Pls advise
inp var nib
inp = INC rev 4 'read inp from Ios
debug ? inp 'FIRST DEBUG
LOOKUP inp , [noparse][[/noparse]2500,3000,3500,4300,1800,2000,2300,
0,3800,3600,3300,4300,3500,3000,2500], w1
debug ? inp 'SECOND DEBUG
The problem is that the first and second debug give
different values?. Is the stamp corrupting the 'inp'
nibble after using it in the Lookup command.In the
manual it doesn't say so . But it seems to be
happening. Anyone with a solution, diagnosis, similar
experiences .Pls comment
__________________________________________________
Do you Yahoo!?
The New Yahoo! Search - Faster. Easier. Bingo
http://search.yahoo.com
inp var nib
Do you Yahoo!?
You've actually created the problem by mixing your own variable declaration
(inp) with a predefined variable name (W0). This is a big NO-NO. In fact, I
very strongly suggest that you DON'T use internal variable names; don't be
lazy ... use named variables and let the compiler assign their location.
What's happening is that inp is the same as W0.Nib0 so when you change W0 you
end up changing inp. You can fix this problem programming by declaring a
named word variable for the output of your LOOKUP function.
-- Jon Williams
In a message dated 4/21/2003 3:49:21 PM Central Standard Time,
suri_list@y... writes:
> Hi
> inp var nib
