WORD moving with << (left) command
Hi!
I've a word looking like this:
1111 1111 1111 1100
This is data read via I2C from an A/D converter (input pin hooked up to
VDD, just for testing). By some reason, the data is not as it should be.
It's shifted 2 postions right. It should look like:
1111 1111 1111 00 00, eg remove the first "11", shift left 2 positions.
Then my value from the A/D should be alright.
So I tried to use the << command, like this:
ad_result = ad_in << 2
ad_result then looks like this:
1111 1100 1111 0011
What I don't understand, is why the first byte (1111 1100) doesn't get
the value 1111 1111?
Or cant the << command work with words?
Any solution to this?
I want to shift the word 2 steps to the left and then replace the ending
"0011" with "0000".
Thanks.
Regards, Johan
1111 1111 1111 1100
1111 1100 1111 0011
"0011" with "0000".
Thanks.
Regards, Johan
10-bit ADC, you can specify whether or not the result is left or right
justified. Maybe this is the same for the chip you are using?
> 1111 1111 1111 1100
> 1111 1100 1111 0011
> "0011" with "0000".
Solved the problem now... My fault.. A missing zero can cause a lot of
trouble.
Rodent wrote:
>Not sure about the AFC you are using, but with the Atmel AVR's that have a
>>1111 1111 1111 1100
>>1111 1100 1111 0011
>>"0011" with "0000".
>from the same email address that you subscribed. Text in the Subject and Body
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
