parallel LCD''s PITA
At 03:52 AM 4/20/03 +0000, chicbears11 wrote:
>I picked up a parallel LCD and it's a major Pain in the Smile!
>It's a Tianma....and I'm not certain what exactly my order of
>operations should be.
You will probably be able to find an appropriate data sheet here:
http://www.tianma.com/products/character_displays/index.html
as well as the type of controller your LCD is using.
Make sure you are setting the LCD to 4-bit or 8-bit mode as appropriate.
There may also need to be an initialization sequence. This should all be
described in the data sheet from the above link.
Bruce Bates
Bruce Bates
