parallel LCD''s PITA
You might try hooking up the contrast line to the middle post on a pot,
and then one of the outside posts to vss. It sounds like exactly what I
had going on, and that fixed it. But mine was Hitachi compatible.
-Mike
From: chicbears11 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=tPRF08g7gzlHllElwCNSFNqxWXXftaWVBxhvxa0a7Aj-UG4V5i5Kz_i4Kr0AzHL-zicKlr0T-Q]buht_krak@s...[/url
Sent: Saturday, April 19, 2003 11:52 PM
Subject: [noparse][[/noparse]basicstamps] parallel LCD's PITA
I picked up a parallel LCD and it's a major Pain in the Smile!
It's a Tianma....and I'm not certain what exactly my order of
operations should be.
I have the inputs of the LCD connected to the top 8 outputs of my
stamp. So I should use OUTH as a command (eg. OUTH = %
00000001 'resets display?).
I have R/W tied low; RS to out4 (on bs2) w/pull-up resistor; E to
out6 (on bs2) w/pull-up resistor.
So....with the outh puttin out the bits that I want....do I pulse E
for the LCD to take it?
I can't seem to get more than the first line solid with
blocks...luckily that happens by just applying power!! haha
Your use of Yahoo! Groups is subject to
-Mike
