Lazer Command
[noparse][[/noparse]Sorry if this appers twice, I posted it before, but it didn't show
up]
Although this is not directly connected to the STAMP, the only thing
the STAMP is used for is to test the output. But lots of people on
here know about electronics.
Anyway :
I am trying the make a cheap Lazer Tag (For Lazer Command).
Is it possible to use a switch connected to a Schimit Trigger (Sorry
about the spelling) that triggers a 555 timmer that drive a few IR
LEDs. But pause after the button press, then pulse for around 5
seconds?
So :
Button : Schimit Trigger : 555 Timer : IR LEDs
Could any one point me to a circuit(s) that will help?
- Ben
up]
Anyway :
seconds?
So :
- Ben
ben@d... writes:
> seconds?
> So :
> Thanks
> - Ben
This can certainly be done with discrete components. Please give more
detail...If I correctly understand you want to do the following.
Button press, fire some IR LEDs, pause (how long?) then fire the LEDs again
for about 5 sec?
More detail please
(Approx.), then it fires the LEDs at 60MHz, then stops (Or a huge
delay, as it will be picked up in under 30mins, or it wont matter)
The pause is to allow it to be thrown and not hit your target, but
start the LEDs when it has came to stop near the target.
Is this enough info?
- Ben
more
LEDs again
> for about 5 sec?
> More detail please
configure the 555 to be a timer? You would also need the thing to make
the LED's flash at 60Mhz...
