Need help reading a schematic — Parallax Forums
edited 2003-04-21 12:58 in General Discussion
I am hoping someone can explain a schematic to me. It is for an IR
transmitter project. I am not sure how to read hot a POT hooks up.
I have a copy of the schematic here
http://www.chadphillips.org/map.html
Any help would be appreciated.
thanks
chad
    edited 2003-04-19 05:07
    There are three terminals on the POT. Connect either outside terminal to the
    middle terminal, this is the right side connection. Connect the resistor to the
    remaining terminal.
    HTH,
    Leroy
    : Hi,
    : I am hoping someone can explain a schematic to me. It is for an IR
    : transmitter project. I am not sure how to read hot a POT hooks up.
    : I have a copy of the schematic here
    : http://www.chadphillips.org/map.html
    : Any help would be appreciated.
    : thanks
    : chad
    : To UNSUBSCRIBE, just send mail to:
    : basicstamps-unsubscribe@yahoogroups.com
    : from the same email address that you subscribed. Text in the Subject and Body
    : Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
    edited 2003-04-19 17:58
    Thanks, that makes sense now.
    Can anyone recommend a book that would explain these types of
    fundementals?
    thanks
    chad
    terminal to the
    resistor to the
    > remaining terminal.
    > HTH,
    > Leroy
    edited 2003-04-19 18:10
    In a message dated 4/19/2003 9:59:31 AM Pacific Daylight Time,
    bear_phillips@y... writes:
    > fundementals?
    > thanks
    > chad
    I would start with your local community college and take a course in basic
    electronics.
    Don't know of any books that would specifically answer your question.
    edited 2003-04-19 18:17
    Chad:
    It may have more info than you are looking for, but if you get the US Navy's
    Basic Electronics and Electricity training manuals, you will never want for
    information again. I didn't see what the original schematic you were looking
    at look liked, but from reading the answers I DID see, it didn't sound like
    anything especially exotic. It sounded like the total R would wind up being
    equal to the portion that was connected in series with the load, since the
    wiper (center terminal) would short out the rest of the pot. All a pot is is
    a wirewound or carbon ribboned resistor, with a slider accross it, and the
    three leads are the two ends of the resistor and the center terminal as the
    wiper. If you think about it, leave the wiper unconnected on a 10Kohm pot,
    and you have a fixed 10K resistor. If you leave one end unconnected, and
    connect to the wiper on one lead and the other outside terminal on the
    other, you have a resistor with whatever is between the wiper and connected
    end as a variable resistance. Shorting one end to center has the same
    effect, but leaves nothing floating, so no stray currents and thus stray
    voltage drops.
    Mic
    Sent: Friday, April 18, 2003 7:30 PM
    Subject: [noparse][[/noparse]basicstamps] Need help reading a schematic
    > Hi,
    > thanks
    > chad
    edited 2003-04-20 00:22
    I might recommend Grob's BASIC electronics series. I used BASIC Electricity &
    BASIC Electronics in my classes and the kids seemed to understand and enjoy
    those..
    Leroy
    : Thanks, that makes sense now.
    : Can anyone recommend a book that would explain these types of
    : fundementals?
    : thanks
    : chad
    : --- In basicstamps@yahoogroups.com, "Leroy Hall" <leroy@f...> wrote:
    : > There are three terminals on the POT. Connect either outside
    : terminal to the
    : > middle terminal, this is the right side connection. Connect the
    : resistor to the
    : > remaining terminal.
    : > HTH,
    : > Leroy
    edited 2003-04-20 00:57
    In a message dated 4/19/2003 4:23:24 PM Pacific Daylight Time, leroy@f...
    writes:
    > those..
    > Leroy
    > : fundementals?
    > : thanks
    > : chad
    > : >There are three terminals on the POT. Connect either outside
    > : terminal to the
    > : >middle terminal, this is the right side connection. Connect the
    > : resistor to the
    > : >remaining terminal.
    > : >HTH,
    > : >Leroy
    As cheesy as this will sound, there are some leaflett books written by Sims
    at Radio Shack. Some of the circuits are indeed suspect, but for "ground
    zero" electronics, this might also be an option.
    edited 2003-04-20 19:22
    Look at the Engineer's Mini-Notebook series from Radio Shack.
    >From: smartdim@a...
    >Reply-To: basicstamps@yahoogroups.com
    >Subject: Re: [noparse][[/noparse]basicstamps] Re: Need help reading a schematic
    >Date: Sat, 19 Apr 2003 13:10:05 EDT
    > > fundementals?
    > > thanks
    > > chad
    >electronics.
    _________________________________________________________________
    Add photos to your e-mail with MSN 8. Get 2 months FREE*.
    http://join.msn.com/?page=features/featuredemail
    Probably one of the easiest books to read with great explanations of how
    various parts work is the Amateur Radio Handbook from the American Radio
    Relay League. Just go to the www.arrl.com web site.
    Jim http://www.geocities.com/jimforkin2003/
    From: Michael Duerksen [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=glwVouktGznZLUYeBxEwm7dN7n1T9OFhx5DNm1F5dTPEPLXhR267adkdaYxcvRkC1dMWf-f01tyvA9jmvhCxXkY]michael_duerksen@c...[/url
    Sent: Saturday, April 19, 2003 1:17 PM
    Subject: Re: [noparse][[/noparse]basicstamps] Need help reading a schematic
    Chad:
    voltage drops.
    Mic
    > Hi,
    > thanks
    > chad
