Simple square wave counter?
Is there a simple way to count incoming pulses from a square wave?
The COUNT function does not do what I want, as it counts edges over a
fixed time period and gives the result. What I am looking to do is
to count pulses from an incoming square wave and do a compare on the
value (ie, count until 40 pulses go by, then turn on an LED.) I am
afraid if I use a pin high to increment a count that I will possibly
get more than one count per pulse. I know that the BUTTON function
will require a low before a new high is counted, but is this the only
way to do this?
way to do this?
doing anything else or just looking for pulses.
Look:
if pin1 = 1 then goto counting
goto Look
Counting:
yourcount = yourcount + 1
if yourcount = 40 then Newcode
goto Look
Newcode:
whatever here
Sent: April 18, 2003 9:04 AM
Subject: [noparse][[/noparse]basicstamps] Simple square wave counter?
> way to do this?
CHANGE on the input pin. Assume that you are monitoring pin0, and that you
want to count 3 pulses.
i var byte
changedbit var bit
changedbit = NOT pin0 ' I'm NOT sure if you can use NOT here. If not,
' use changedbit = 1-pin0
i = 0
loop:
if pin0 <> changebit then loop
' pin0 has changed state
toggle changedbit
i = i + 1
if i > 6 then turnonled
goto loop
turnonled:
' Turn on the led
i = 0
goto loop
Assume that when the program starts, pin0 is in the 0 state. "changedbit"
is tracking the state of pin0; we set it to be the opposite of pin0
initially (in this case, to 1).
The "if" will be true, and the program will loop until pin0 is a 1 (rising
edge of the square wave). At this point we toggle "changedbit", so it will
now be 0. We increment the counter and go back to monitoring pin0. The
program will now loop until pin0 is 0 (different from "changedbit") - the
falling edge of the square wave. we increment the counter once more, and
toggle "changedbit".
We now have monitored a complete pulse, and the counter "i" is at 2. We
have counted the number of CHANGES in pin0. Since we want to know when 3
pulses have occurred, and since we get 2 counts per pulse (rising and
falling edges), we need to terminate the count at 6, not 3.
If you want to count complete square waves (i.e. you don't want the count
to terminate until the rising edge of the 4th square wave (three complete
on and off cycles), the count would need to be 7, not 6, so that the next
rising edge is counted.
Parallax has an appnote 20 "An Accurate Time base" that uses this technique
Have fun!
Larry
>way to do this?
Larry Bradley
Orleans (Ottawa), Ontario, CANADA
>way to do this?
How fast? It is possible if it is relatively slow (less than
somewhat in the 100s of hertz, depending on which Stamp you are
using). Here is a way using state variables to detect the rising
edge on p0:
'{$PBASIC 2.5}
x0 var bit ' old state of pin
x1 var bit ' new state of pin
xx var bit ' change in state of pin
LED pin 1
counter var byte
do
x1 = in0
xx = x1 ^ x0 & x1
counter = counter+xx max 40
x0=x1 ' update old state variable
if counter=40 then high LED ' turn it on
next
-- best regards
Thomas Tracy Allen PhD
http://www.emesystems.com
mailto:tracy@e...
> LED pin 1
> counter var byte
> do
> x1 = in0
> xx = x1 ^ x0 & x1
> next
loop ' not next!!! mixing up pBasics
really impressed.
> > '{$PBASIC 2.5}
> > next
