fast RCTIME — Parallax Forums
fast RCTIME
edited 2003-04-20 02:55 in General Discussion
Hello all,
I am working on a project that requires the measurement of around
20 potentiometers. What makes things worse is that I would like it to
be somewhere around realtime, say 40 potentiometer reads per second.
I have looked back about a year's worth of posts concerning RCTIME,
and people seem to agree that the best way of doing this is reducing
either the capacitor or potentiometer values, but that will of course
reduce precicion, which isn't really a big deal. So my question is
this: If I want to keep 6-7 bits of precision, what is the smallest
resistor/capacitor combination I can use which doesn't pose an
operational threat to my BS2p40. Barring that, if I have to test
various combinations myself (which is completely fine by me) what
should the lower bounds of my tests be so that I don't burn out my
chip. Any input would be appreciated. Thanks.
Stefan Dorsett
    edited 2003-04-18 18:04
    >Hello all,
    > Stefan Dorsett
    Okay, a BS2p40 with enough pins. If you put a protection resistor in
    series with the Stamp input pin there is nothing to worry about wrt
    burning it out.
    potentiometer
    R1 ;---;
    Vss --/\/\--/\/\---o
    P0
    /\/\----o pin protection resistor
    330 |
    ===== capacitor
    | film
    Vss
    In one second, with 40 potentiometers, you can allow over 25000
    microseconds for each RCtime command. Take away 2 milliseconds for
    the interpreter, that leaves 23000 microseconds for the result.
    Since the BS2p gives units of 0.9 microseconds, the resolution is
    still theoretically about 1 part in 25000. That is better than 14
    bits. The practical limit on the RCtime command is around 10 bits.
    Choose the capacitor, the potentiometer and the resistor so that the
    minimum time will be around 200 microseconds and the maximum time
    will be around 1000 microseconds. That will meet your required
    precision. In the circuit shown, the capacitor is initially charged
    high and discharges thru the potentiometer+R1 circuit. The time to
    discharge to the Stamp switching threshold is about:
    tm = 1.347 * R * C
    do
    RCtime 0,1,mytime
    high 0
    loop
    More RCtime info at:
    http://www.emesystems.com/BS2rct.htm
    -- best regards
    Tracy Allen
    mailto:tracy@e...
    edited 2003-04-18 21:05
    --- In basicstamps@yahoogroups.com, Tracy Allen <tracy@e...> wrote:
    > >Hello all,
    around
    to
    second.
    reducing
    course
    > > Stefan Dorsett
    in
    > burning it out.
    > potentiometer
    > R1 ;---;
    > P0
    > 330 |
    > ===== capacitor
    > | film
    > Vss
    for
    the
    charged
    > tm = 1.347 * R * C
    > do
    > RCtime 0,1,mytime
    > high 0
    > loop
    > -- best regards
    > Tracy Allen
    > mailto:tracy@e...
    Wow, thanks. The part about me not burning out my chip helps a lot,
    as I imagine I'll be tweaking various potentiometer/resistor values
    far past the time it is healthy for me to be doing so. However,
    another thought on this subject came to me last night in bed: Since
    most of the time in the RCTIME command is essentially executing nops,
    waiting for the pin to reach logic low, I'm wondering if it would be
    possible to execute, say, four RCTIME commands at once, and check
    every fourth cycle. This would reduce precision, but to a very small
    level, only up to three cycles in this case. I doubt the RCTIME
    command has anything like this, but is it possible to reconstruct the
    RCTIME command so that it enables this. In short, is RCTIME hardware
    implemented or software. And if it is software, are there any
    resources available to me to be able to recode it? Any thoughts would
    be appreciated. Thanks again.
    Stefan Dorsett
    edited 2003-04-18 21:26
    1. The Basic Stamp is NOT a multi-processing beast.
    It does one thing at a time. Interleaving is not possible.
    2. The RCTime expects you to have charged a capacitor on
    the pin, and then when you execute the RCTime instruction
    itself, it runs a counter until the pin changes state.
    It is NOT doing 'NOP's, it's incrementing a counter
    and monitoring the pin. You can't do that to 4 at
    once.
    Having said that, the Basic Atom can be convinced to do
    a FORM of Basic Interrupts, and it has timers, so you
    in theory could do the same thing yourself.
    In practice, the resolution and accuracy you're looking
    for make even the Atom's pseudo interrupts chancy.
    The BS2p40 looks like the best bet.
    --- In basicstamps@yahoogroups.com, "Stefan Dorsett"
    > > >Hello all,
    > around
    it
    > to
    > second.
    RCTIME,
    > reducing
    > course
    is
    smallest
    my
    > > > Stefan Dorsett
    resistor
    > in
    wrt
    > > burning it out.
    > > potentiometer
    > > R1 ;---;
    > > P0
    > > 330 |
    > > ===== capacitor
    > > | film
    > > Vss
    > for
    14
    bits.
    > the
    required
    > charged
    to
    > > tm = 1.347 * R * C
    > > do
    > > RCtime 0,1,mytime
    > > high 0
    > > loop
    > > -- best regards
    > > Tracy Allen
    > > mailto:tracy@e...
    nops,
    be
    small
    the
    hardware
    would
    > Stefan Dorsett
    edited 2003-04-19 02:20
    Ok, true. Both points 1 and 2 make sense, and they help me get a
    better grasp of what the basic stamp can do. However, there are a few
    things I have found out from the documentation that make me wonder if
    it is possible. First, I require the 32 I/O pins on the BS2p40, so I
    am going to work around this model. the BS2p, unlike the earlier
    models, have polling functions which look like they would be able to
    support a sort of parallelism:
    Capacitors and potentiometers work in parallel, so why should we
    wait for each to discharge in turn when we can discharge all of them
    at once? My solution is to charge and POLLIN all of the pins we would
    have used RCTIME on, set POLLMODE, increment a counter until one of
    the pins polls, break to a list of IF statements to figure out which
    pin polled, save the counter as an index to that pin, and continue
    from polling the other pins from there. I realize this will introduce
    extra cycles into the total count, but if I only need 6-7 bits of
    precision and RCTIME is accurate up to 10, this shouldn't be an
    issue. I don't know if this code will work, as I have yet to get my
    stamp, and this is just speculation, but I like to start early on
    theory. My only other concern at this point would be just how many
    pins POLLIN can reasonably poll inbetween instructions, and the
    constant overhead for figuring out which pin polled. If this works,
    hopefully I can go from 2 refreshes per second to maybe 4 or 5,
    depending. Well, what do you think? Any input is appreciated. Thanks.
    Stefan Dorsett
    --- In basicstamps@yahoogroups.com, "Allan Lane" <allan.lane@h...>
    > once.
    wrote:
    > > > >Hello all,
    > > around
    like
    > it
    > > to
    > > second.
    > RCTIME,
    > > reducing
    > > course
    question
    > is
    > smallest
    test
    what
    out
    > my
    > > > > Stefan Dorsett
    > resistor
    > > in
    > wrt
    > > > burning it out.
    > > > potentiometer
    > > > R1 ;---;
    > > > P0
    > > > 330 |
    > > > ===== capacitor
    > > > | film
    > > > Vss
    milliseconds
    > > for
    is
    > 14
    > bits.
    that
    > > the
    time
    > required
    > > charged
    time
    > to
    > > > tm = 1.347 * R * C
    > > > do
    > > > RCtime 0,1,mytime
    > > > high 0
    > > > loop
    > > > -- best regards
    > > > Tracy Allen
    > > > mailto:tracy@e...
    lot,
    values
    Since
    > nops,
    > be
    > small
    > the
    > hardware
    > would
    > > Stefan Dorsett
    edited 2003-04-19 16:05
    Hi Stefan,
    If each RCtime reads from 0.1 to 1 millisecond, and the overhead for
    each one is 1 millisecond, then you could read all 20 potentiometers
    in something less than 50 milliseconds. That would be fast enough
    for 20 updates per second
    By the way, be careful for your circuit layout, to minimize stray
    capacitance and long leads.
    The scheme using pollmode might work too (DIY parallelism), but I
    don't guess it would enable faster scanning. The counting done by
    the interpreter is going to be on the time scale of milliseconds,
    whereas the RCtime command counts on the time scale of microseconds.
    To count up to 64 (6 bits accuracy) will take on the order of 64
    milliseconds, which is no better than the straight RCtime scheme.
    -- Tracy
    > Stefan Dorsett
    Ah, thank you. That makes sense. So I guess that makes RCTIME closer
    to a hardware implementation than software, or the commands given in
    PBASIC aren't at the assembly level. I'm thinking it is more the
    hardware part, but I would be curious as to how they implement it.
    I'll try to let you guys know how the project goes, or in the likely
    event that I need more help, I'll post again. Thanks all.
    Stefan Dorsett
    > Hi Stefan,
    for
    potentiometers
    microseconds.
    > -- Tracy
    few
    if
    I
    to
    them
    would
    which
    introduce
    Thanks.
    > > Stefan Dorsett
