Complete Newbie wants to test understanding :)
Hi all! Been lurking a while, unabashedly stealing all kinds of neat
ideas. [noparse]:)[/noparse]
Have a project I'm considering, and I'd like some input from the
experts to let me know if I'm even close to the right track, or way
off base.
Project is an indexing system for a model railroad turntable. (Yeah,
I know, I can buy one cheaper than it'll cost me to build it, but
where's the fun in that??)
Basic Requirements:
Run a 12V DC motor. Speed and Direction control would be nice, but
not strictly necessary.
Stop the motor when the light of an infrared sensor pair is
interrupted by, say, a block of wood on the bottom of the turntable
rotating past.
Allow the turntable to continue past an interruption if a pushbutton
is being held down at the time the beam is broken...allowing the
turntable to "skip" an index, and proceed to the next.
My thinking on this is that I should be able to do this with the
following, or something close:
12V DC motor and 12V power supply
A BS2
Some sort of infrared sensor pair with an open collector that either
goes low or high when the beam is interrupted. (Have found such a
pair for ~$15)
An L293D motor driver. This would provide directional, but not speed
control if I understand things correctly?
A push button
Basically, my thinking is I could use one BS2 input, connected to the
sensor's output, and monitor it for a signal. As long as a signal
was present, spin the motor. I could choose motor direction with
something as simple as a toggle switch, or some other condition I
could later set to be monitored on nother input. The pushbutton
would force the sensor circuit to be closed, and thus high,
regardless of the sensor's state. Finally, 3 BS2 outputs would be
used to control the L293D, which then has plenty of power (voltage
AND current) to drive a simple DC hobby motor.
So, great and wise experts...am i loony tunes, or on something that
resembles the right track? I'm more than willing to do the research
and put out the effort necessary to learn my way around PBasic,
troubleshooting, etc. But it sure would be nice to know I'm not
heading in totally the wrong direction before I drop $100 or so into
this to get started. [noparse]:)[/noparse]
Thanks in advance to anyone who responds, and I appologize for the
long post first time out.
gb
off base.
Basic Requirements:
rotating past.
A BS2
pair for ~$15)
A push button
gb
like you are on the right track -- pun intended. Just take it one small
function at a time and you should be fine. The only big item I don't see is
a breadboard to build the prototype. If you don't already have one, I
suggest the Board of Education Complete Kit because it provides everything
you need to program your stamp, including the BS2. Then you can add your
sensors, switches and motor control one step at a time. You'll also need a
small assortment of resistors and capacitors.
Have fun! Post some pictures when you get it working. I love model
railroads.
-- Al Margolis, founder
www.hobbyengineering.com
The WEB's newest source for robotics supplies and information
From: gboulton3nf [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=EPGUDleF0IfIwTlG7u1UGomwL2GJkCvDNAkPK9f6_IQjNYxISCFTkSLdg1iweP9YIX4ngwBl82MI-NDk1Q]gboulton@p...[/url
Sent: Thursday, April 17, 2003 5:33 PM
Subject: [noparse][[/noparse]basicstamps] Complete Newbie wants to test understanding [noparse]:)[/noparse]
off base.
Basic Requirements:
rotating past.
A BS2
pair for ~$15)
A push button
gb
gboulton@p... writes:
> gb
Sounds like a simple task for a BS2. What you described sounds like you want
to control a motor based simply on 2 or 3 TTL level inputs.
The BS2 (or BS1) should easily handle this job.....
Ken
A month or few back, another person on the list was doing a RR project
similar to this. He had said that lining up IR sensor was a pain on the
train ;-)
I thought a Hall sensor might be better than IR. The hall sensor would be
able to detect the magnets in the locomotive. It would also be easy to put
tiny NIB magnets on any car you wanted to detect. You could even do things
like calculate speed, determine how many car are in a train , all sorts of
stuff. This set up should be easier to hide than a IR gate, and no alignment
issues.
I'm not sure if he went with Hall sensors or IR, but look up in the archives
and get hold of him, as model RR guy who is into Stamps, I'm sure he will
have all kinds of good ideas for you.
Jonathan
www.madlabs.info
Sent: Thursday, April 17, 2003 5:32 PM
> off base.
> Basic Requirements:
> rotating past.
> A BS2
> pair for ~$15)
> A push button
> gb
Wanted to thank all of you who took the time to provide some input.
As it turns out, I've found a considerably less expensive way to
accomplish the task, using an old stepper motor and control circuitry
from old 5 1/4" floppy drives. The prototype system is about 90%
complete, with only a few minor bugs left to be worked out. If any
railroaders out there are interested in the process, give me an e-
mail @ gboulton@i...
Thanks again to all of you who helped out, and gave some insight.
I'm sure I'll keep lurking, as I have future projects for which a BS2
would be perfect.
gb
--- In basicstamps@yahoogroups.com, "gboulton3nf" <gboulton@p...>
neat
> off base.
(Yeah,
> gb
