instruction execution times...
A question:
If I have a PULSOUT instruction, does the stamp wait the duration of
the pulse before executing the next instruction? i.e., if I have a
simple loop to flash an LED, such as:
Loop:
PULSOUT 13, 2000
Pause DelayTime
GOTO Loop
Does the value of the Pulse duration (2000 in this case) affect the
length of time it takes the loop to execute?
Jeff
A question:
Loop:
PULSOUT 13, 2000
Pause DelayTime
GOTO Loop
Jeff
the period to elapse before going on to the next statement.
At 08:56 PM 4/17/2003 +0000, you wrote:
>Hi,
> A question:
>Loop:
> PULSOUT 13, 2000
> Pause DelayTime
> GOTO Loop
>Thanks,
> Jeff
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Larry Bradley
Orleans (Ottawa), Ontario, CANADA
until that thing is done the next instruction DOES
NOT Execute. So instructions with 'durations'
(like PULSOUT, SEROUT, SERIN with a timeout,
even SLEEP and PAUSE) will run to completion before
any following instruction executes.
This is both a little irritating (I'd LOVE to multi-task)
and reassuring (it is a simple model, easily worked with).
--- In basicstamps@yahoogroups.com, "bisbeejeff" <kennedy@t...> wrote:
> Hi,
> A question:
of
> Loop:
> PULSOUT 13, 2000
> Pause DelayTime
> GOTO Loop
> Thanks,
> Jeff
