power measurements
I made a power measurement for a 3 phase, whye connection, industrial
wave solder machine and obtained what I thought of as awkward data.
The power factor readings were as follows:
PF for L1 = -0.11
L2 = 1.00
L3 = 0.87
Is there an explanation for such a variation between each leg of a
single piece of equipment?
Thanks in advance
PF for L1 = -0.11
L2 = 1.00
L3 = 0.87
Thanks in advance
Sent: Thursday, April 17, 2003 4:33 PM
Subject: [noparse][[/noparse]basicstamps] RE: power measurements
> PF for L1 = -0.11
> L2 = 1.00
> L3 = 0.87
> Thanks in advance
getting a -no load- on one phase means it is not connected. check
the fuses, it may be that one fuse is blown on that phase.
bet the motor is getting hot.
If you are deaing with a variable speed drive, test it at a frequency
above about 50 Hz. most amp probes are not designed for reading
lower frequencies.
Dave
industrial
data.
> PF for L1 = -0.11
> L2 = 1.00
> L3 = 0.87
> Thanks in advance
phase and ground.
Larry
Sent: April 24, 2003 7:25 AM
Subject: [noparse][[/noparse]basicstamps] Re: power measurements
> sounds like the motor is single phasing.
> lower frequencies.
> Dave
> industrial
> data.
> > PF for L1 = -0.11
> > L2 = 1.00
> > L3 = 0.87
> > Thanks in advance
