Toshiba Laptop and BS-2 Problem — Parallax Forums
edited 2003-04-18 15:05 in General Discussion
HI Gang:
I have a problem communicating with my BS-2 with my Toshiba Tecra 8100
laptop. I get the dreaded "No Basic Stamp found" message. It is running
windows 2000 Professional. My BS-2 is fine since I can program it with my
Dell P-3 computer running windows 2000 Pro also. I have checked the serial
port settings on both computers and they are identical. Any suggestions??
Al Sines, W3AL
    edited 2003-04-17 18:00
    Al:
    You seem to be having the same problems a nephew of mine is having, except
    his is on a Dell 2500 Desktop. I can communicate with his Stamp 2 using
    either my Compaq (Older one) laptop or my Packard Bell Desktop, or my Dell
    4500 desktop, but he cannot seem to get his Dell to communicate with it. It
    would appear that the problem is not computer brand related. If I find the
    solution I will, of course, let the list know and please if you find it first
    let the list know. It is strange.
    Randy
    edited 2003-04-17 18:12
    In a message dated 4/17/2003 10:04:06 AM Pacific Daylight Time,
    cnc002@a... writes:
    > Al:
    > It
    > first
    > Randy
    Dont have this laptop for problem, but I remember reading posts about the
    problem. I believe you have to disable FIFO on your lap top. There is
    information at the Parallax web sight.
    edited 2003-04-17 18:24
    The bs-2 is not true RS232. it was designed to expect +/-12v from
    the PC. Newer computers and laptops have +/-5V on the RS232.
    If it were designed to be truely compatible with rs232 it would work
    down to the +/-3V levels.
    The problem is related to newer computers in general. I suspect most
    manufacturers have switched to lower voltages for power savings
    resons (never to return); however, the problem lies in the bs-2
    design. It will have to change.
    edited 2003-04-17 19:24
    Yes I had the same problem with a Toshiba Laptop too.
    Seems the voltages on the RS232 chip are not exactly
    true levels. Try plugging it in. It may work, it may not.
    Sent: Thursday, April 17, 2003 16:31
    Subject: [noparse][[/noparse]basicstamps] Toshiba Laptop and BS-2 Problem
    > HI Gang:
    serial
    > Thanks,
    > Al Sines, W3AL
    edited 2003-04-17 22:58
    Yes, disable the FIFO buffers and it should work.
    Jonathan
    Sent: Thursday, April 17, 2003 10:12 AM
    Subject: Re: [noparse][[/noparse]basicstamps] Toshiba Laptop and BS-2 Problem
    > cnc002@a... writes:
    > > Al:
    except
    Dell
    > > It
    the
    > > first
    > > Randy
    edited 2003-04-17 23:48
    If thats the case, then perhaps you could make a simple booster using a
    max233 rs232 driver, I use one with bs2 to make true rs232 from 0-5v out of
    my stamp. It requires no external caps etc, and will boost the voltages to
    around 12 to -12 volts.
    Jan Axelsons book "Serial port complete" has all the schematics etc.
    Cheers,
    Chris
    Sent: Friday, April 18, 2003 1:24 AM
    Subject: [noparse][[/noparse]basicstamps] Re: Toshiba Laptop and BS-2 Problem
    edited 2003-04-18 00:33
    I have been using Toshiba Laptops to talk to Stamps since they were invented.
    I started with a 486, and three Satellite models, and now have a PIII 700 MHz
    Satellite without a serial port. I had to buy a Keyspan USB to Serial adapter
    for this computer. All have worked fine with the Stamp II's and a 25 foot
    serial cable, in a welding shop.
    I would look for other problems, or it may be a problem with your particular
    computer.
    Hope this is not redundant information, I did not see the first part of the
    message.
    Alan Bradford
    Plasma Technologies
    edited 2003-04-18 01:17
    I have a Toshiba Libretto 50CT that will "only" talk to a particular
    datalogger if it is set to high power mode. It works fine with everything
    else, including Stamps.
    edited 2003-04-18 01:20
    Alan,
    Odd, I have a Satellite Pro which needed the FIFOs disabled, and a friend
    experienced the same thing on another Toshiba, not sure of the model.
    Several other members have found this fix to work as well. Wonder why your's
    are ok?
    Jonathan
    www.madlabs.info
    Sent: Thursday, April 17, 2003 4:33 PM
    Subject: Re: [noparse][[/noparse]basicstamps] Re: Toshiba Laptop and BS-2 Problem
    > Hi,
    invented.
    MHz
    adapter
    particular
    > computer.
    the
    > message.
    > Alan Bradford
    > Plasma Technologies
    edited 2003-04-18 04:07
    To: Jon and all of you that responded, thank you very much!
    My Toshiba laptop is now talking to my BS-2 and BS-2p. It was the FIFO that
    had to be disabled. I goofed initially and failed to uncheck the "automatic
    configuration" once that was done and set to "use current settings" (current
    settings with FIFO disabled) it worked perfectly.
    Again, thanks to all.
    Al Sines, W3AL
    Sent: Thursday, April 17, 2003 20:20 PM
    > Alan,
    your's
    > are ok?
    > Jonathan
    > www.madlabs.info
    > From: <plasmastamp@a...>
    > > Hi,
    > invented.
    700
    > MHz
    > adapter
    foot
    > particular
    > > computer.
    > the
    > > message.
    > > Alan Bradford
    > > Plasma Technologies
    and
    Yes, I have this problem with my Toshiba at home
    (Sorry, forgot the model number).
    "232 settings" usually means something like
    baud rate, parity, stop-bits. It doesn't usually
    include FIFO buffer setting -- BUT my Toshiba
    REALLY complains if you try to program a BS2 with
    FIFO turned on (and it won't program it).
    Win 2000 Easiest fix:
    Click Start, Settings, Control Panel.
    Select System, Hardware Tab, Device Manager button.
    Click 'Ports' entry. Double-click the Com port you want.
    Click 'Port Settings' Tab. Click 'Advanced' button.
    -- Finally, you are on the right page!
    -- Thanks Microsoft.
    Click on the 'Use Fifo buffers...' check box, so it
    is CLEAR. Click 'OK'.
    You don't need to reboot your PC for this to work.
    You COULD lower the 'Transmit Buffer' and 'Receive Buffer'
    settings to 0 to get the same effect -- but clicking the
    'Use Fifo buffers...' box is easier to undo.
    Good luck! AllanL
    --- In basicstamps@yahoogroups.com, plasmastamp@a... wrote:
    > Hi,
    invented.
    PIII 700 MHz
    Serial adapter
    25 foot
    particular
    > computer.
    part of the
    > message.
    > Alan Bradford
    > Plasma Technologies
