Converting to TTL levels
Hi All,
I am working on a project that requires me to decode 9 bits (9 input
pins) of binary code that may (unusually) be high at +28V, (30V
absolute max). The same input pins need to have the flexability to
work with +12V highs. All lows are ground level.
Can anyone suggest a way that I can convert these input parameters
so that the stamp can deal with them? Is there an IC package that
converts higher voltages to TTL levels?
REgards,
Dwain.
REgards,
Dwain.
dwainsworld@e... writes:
> Hi All,
> REgards,
> Dwain.
Dwain,
You can easily convert the 12 to 28 volts to TTL level signals. Two options
immeadiately come to mind.
1) use a 2n3904 transistor......connect emitter to ground, connect the
collector to one end of a 4.7k ohm resistor, the other end of the 4.7k ohm
resistor to +5v.
Also connect the colloector to the stamp input pin (many suggest to do this
through a resistor for protection - 100 ohms should be sufficient)
Connect 300k (or 500k) ohms to the base of the transistor. Connect your 12 to
28 volt source to the other end of the 300k ohm resistor.
When 12 to 24 volts is present, the stamp will recieve a logic zero and visa
versa. If the transistor must switch on and off really fast......The resistor
values and circuit will need some tuning to speed up the turn on and turn off
time of the interface circuit. The values used are just a starting point if
switching speed is not a concern.
2) the second idea is to use an opto isolator (4n35).
If you need more clarification on either idea, write back, or send me a FAX
number off list and I can send you a schematic.....
Ken
From the signal line, connect one end of a 5 k Ohm resistor. To the
other end of the resistor connect the cathode end of a 5.1 Volt zener
diode. Ground the anode end of the zener. The junction of the zener
and the resistor will go from +5.1 Volts to -0.5 Volts, which is within
the design guidelines for ttl logic.
From: smartdim@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=IftvewWMcJWABxChBI_NVFZmSwyveFL5han13kVIuFzmh8g_oYoEhLNrfzEyqh4UXLtObqnJobKy7sk]smartdim@a...[/url
Sent: Tuesday, April 15, 2003 10:12 AM
Subject: Re: [noparse][[/noparse]basicstamps] Converting to TTL levels
In a message dated 4/15/2003 5:51:46 AM Pacific Daylight Time,
> Hi All,
> REgards,
> Dwain.
Dwain,
options
ohm
resistor to +5v.
this
12 to
visa
resistor
turn off
if
FAX
Ken
Your use of Yahoo! Groups is subject to
