74hct595
Archiver
How do I control a 74hct595 with my BS 1 or a PIC ??
Ren
Ren
Regards
Adrian
'{$STAMP BS2}
' Program: 74HC595.BS2 (Demonstrate 74HC595 shift register with
Shiftout)
' This program demonstrates the use of the 74HC595 shift register as
an
' 8-bit output port accessed via the Shiftout instruction. The '595
' requires a minimum of three inputs: data, shift clock, and latch
' clock. Shiftout automatically handles the data and shift clock,
' presenting data bits one at a time on the data pin, then pulsing the
' clock to shift them into the '595's shift register. An additional
' step--pulsing the latch-clock input--is required to move the shifted
' bits in parallel onto the output pins of the '595.
' Note that this application does not control the output-enable or
' reset lines of the '595. This means that before the Stamp first
' sends data to the '595, the '595's output latches are turned on and
' may contain random data. In critical applications, you may want to
' hold output-enable high (disabled) until the Stamp can take
control.
DataP CON 0 ' Data pin to 74HC595.
Clock CON 1 ' Shift clock to '595.
Latch CON 2 ' Moves data from shift register to output
latch.
counter VAR BYTE ' Counter for demo program.
' The loop below moves the 8-bit value of 'counter' onto the output
' lines of the '595, pauses, then increments counter and repeats.
' The data is shifted msb first so that the most-significant bit is
' shifted to the end of the shift register, pin QH, and the least-
' significant bit is shifted to QA. Changing 'msbfirst' to 'lsbfirst'
' causes the data to appear backwards on the outputs of the '595.
' Note that the number of bits is _not_ specified after the variable
' in the instruction, since it's eight, the default.
'counter = 3
Again:
ShiftOut DataP,Clock,msbfirst,[noparse][[/noparse]counter] ' Send the bits.
PulsOut Latch,1 ' Transfer to
outputs.
Pause 500 ' Wait briefly.
counter = counter+1 ' Increment counter.
GoTo Again ' Do it again.
PIC) or microprocessor (8088-468-Pentium) should do.
--- In basicstamps@yahoogroups.com, Ren
I used this before but I want to use the BS1 or a PIC to get the cost down.
I found this but i can't get it right.
Simulate BS2 Shiftin and Shiftout
Symbol DDIR = Dir0 ' Shift data pin direction is Dir0
Symbol DPIN = Pin0 ' Shift data pin is 0
Symbol CPIN = 1 ' Shift clock pin is 1
Symbol I = B2 ' Loop counter
' Shift in some data
Low CPIN ' Start shift clock low
GoSub shiftin ' Shift in some data
' Shift out some data
B0 = 100 ' Data to shift out
GoSub shiftout ' Go do it
End
' Subroutine to synchronously shift in one byte
shiftin: DDIR = 0 ' Set data pin direction to input
For I = 1 to 8 ' 8 bits to a byte
B0 = B0 * 2 ' Shift result 1 bit to the left
Toggle CPIN ' Toggle shift clock
Bit0 = DPIN ' Move data into LSB
Toggle CPIN ' Toggle shift clock once more
Next I ' Loop
Return ' Go back to caller
' Subroutine to synchronously shift out one byte
shiftout: DDIR = 1 ' Set data pin direction to output
DPIN = Bit0 ' Data out is LSB
B0 = B0 / 2 ' Shift byte 1 bit to the right
Next I ' Loop
Where in tihs is my LOAD command ???
Ren
The SEROUT/SERIN commands are for UART type signals --
they have a specified BAUD rate, which the '595 knows
nothing about.
And, the BS1 does not have the SHIFTIN/SHIFTOUT commands,
which the BS2 would use to control a '595.
So, you have to emulate the SHIFTIN/SHIFTOUT commands in
the BS1 to use the '595.
' BS1 Code (Shiftout.BAS)
BSAVE ' Make Code.OBJ of this.
Symbol SerData = 0 ' SerData Pin
SYMBOL SerClk = 1 ' SerClk Pin
Symbol DataByte = B0 ' Zeroth Reg Byte
Symbol Temp = B1 ' First Reg Byte
LOW SerData
LOW SerClk
MainLoop:
DataByte = $0F ' Or whatever you want...
GOSUB SendByte
GOTO MainLoop
SendByte:
FOR Temp = 1 to 8
IF Bit0 = 1 THEN OutputOne ' Bit0..7 Are B0 bits...
' ELSE
GOTO OutputZero
OutputOne:
HIGH SerData
GOTO ForNext
OutputZero:
LOW SerData
ForNext:
Pulsout SerClk, 1
DataByte = DataByte / 2 ' Shift Down
Next
RETURN
--- In basicstamps@yahoogroups.com, "Dave Mucha" <davemucha@j...>
wrote:
> isn't it with any serial instructions ? micro contorller (BS1 or
The 74HCT595 is a Serial In (from Stamp) to
Parallel OUT (to the world) chip. It is
to send bits out to the world -- you can't
read its parallel pins back into the Stamp.
The 74hct165 is a Parallel In (From World) to
Serial Out (To Stamp). You use this chip
to read parallel data from the world into
the stamp -- interfacing is similar.
See the Phillips website, which has PDF
documents of both chips for more detail.
The BS1 is awfully limited in terms of pins,
and speed, especially compared to a PIC.
Still, the principle applies:
To output, set the Data bit, pulse the Clock bit,
set the next Data Bit .. repeat 8 times per byte.
To Input (from a '165), set the Data bit as input,
Pulse the clock bit, read the first data bit,
pulse the clock bit, read the next data bit,
.. repeat 8 times per input byte.
--- In basicstamps@yahoogroups.com, "Allan Lane" <allan.lane@h...>
wrote:
> Hello again.
