BS2sx getting color data back from cmucam
I'm having trouble figuring out how the min and max color values work
with the TC commands for the cmucam. I've tried TC 255 255 255 0 0 0
thinking that that should return a bounding box around the entire
field of view (because that range encompasses all colors) but I keep
getting back 0 0 0 0 0 0 for whatever range of colors I try. The
first three numbers are the max values right? What about "TC 255 100
0 0 0 150", 150 is greater than 0...how is this interpretted?
As I read the TC command (both in Parallax' Boe-Bot CMUcam Manual v1.1 and
the CMUcam Manual v2.00 for the CMUcam v1.12 firmware, from
http://www-2.cs.cmu.edu/~cmucam/), the format is:
TC Rmin, Rmax, Gmin, Gmax, Bmin, Gmax
Further, there is a note that the color values range from 16 to 240.
Based on that information, should not the description of all colors should
read like:
TC 0, 255, 0, 255, 0, 255
TC 16, 240, 16, 224, 16, 224
What return packet type are you getting?
You might also try successively flooding the field of view with a single
color (maybe use something like construction papers), and using the TW
command and observing the S-type return packet color values the different
colors.
HTH,
Daniel
From: Sam [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=0ePSjUVwbR_lL8iZtHvLC6s6Ib8YJOJQDsIF5bw5bbfD74kwEbs-VyqdtS7hI7LXngA93JSxWI-rBh1OS40]hard-on@t...[/url
Sent: Friday, April 11, 2003 11:37 AM
Subject: [noparse][[/noparse]basicstamps] BS2sx getting color data back from cmucam
