BS2 and Visual Basic....urgent help needed!
Folks,
i'm trying to finish up a project and i'm having a serious problem:
i'm trying to send a data from a VB application to a BS2, but it
looks like the basic stamp is not receiving the right input from the
VB application for some reason.below are my BS2 code and my VB code.
I would really appreciate any help
*******************BS2 code*************************************
'{$STAMP BS2p}
datain var byte 'contains a 0 or a 1
pin con 16 'stamps dedicated serial input pin
baud con $4054 '9600 baud
again:
serin pin,baud, [noparse][[/noparse]datain]
if datain = "1" then on
if datain = "0" then off
if datain > "1" then bob
goto again
bob:
SEROUT 0, 241 + $4000, [noparse][[/noparse]170]
goto bob
on:
high 0 'make pin 0 high
goto on
off:
low 0 'make pin 0 low
goto off
comments: it is going to the function "bob" all the time, no matter
what i send from the VB application.
****************************VB code********************************
Option Explicit
Private Sub DataGrid1_ButtonClick(ByVal ColIndex As Integer)
If ColIndex = 1 Or ColIndex = 2 Or ColIndex = 3 Or ColIndex = 4 Then
List1.Top = DataGrid1.Top + DataGrid1.RowTop(DataGrid1.Row) +
DataGrid1.RowHeight
List1.Left = DataGrid1.Left + DataGrid1.Columns(ColIndex).Left
' Width and Height properties can be set a design time
' The width of the list does not have to be the same as the
width of the grid column
List1.Width = DataGrid1.Columns(1).Width
List1.Height = 600
List1.Visible = Not List1.Visible
End If
End Sub
Private Sub Exit_Click()
End
End Sub
Private Sub List1_Click()
Dim x As Variant
Dim SerData As Integer
DataGrid1.Text = List1.Text
If DataGrid1.Text = "on" Then
If MSComm2.PortOpen = False Then
'check to see if the commport isn't already open
MSComm2.PortOpen = True
'open the Commport
End If
SerData = 1
MSComm2.Output = Str(SerData) & "!"
MsgBox "Device 1 is being powered on"
ElseIf DataGrid1.Text = "off" Then
'open the Commport
End If
SerData = 0
MsgBox "Device 1 is being powered off"
End If
List1.Visible = False
End Sub
Private Sub DataList1_LostFocus()
End Sub
Private Sub DataGrid1_Scroll(Cancel As Integer)
End Sub
Private Sub Form_Load()
Dim temp As String
Dim ind As Integer
temp = DataGrid1.Columns(1).Text
If temp = "on" Then
ind = 0
ElseIf temp = "off" Then
ind = 1
End If
List1.AddItem ("on")
List1.AddItem ("off")
DataGrid1.Columns(1).Text = List1.List(ind)
DataGrid1.Columns(1).Button = True
DataGrid1.Columns(2).Button = True
DataGrid1.Columns(3).Button = True
DataGrid1.Columns(4).Button = True
End Sub
Private Sub Update_Click()
Adodc1.Recordset.Update
End Sub
'{$STAMP BS2p}
again:
goto again
bob:
goto bob
on:
goto on
off:
goto off
Option Explicit
DataGrid1.RowHeight
List1.Height = 600
End If
End Sub
End
End Sub
Dim x As Variant
'open the Commport
End If
SerData = 1
'open the Commport
End If
SerData = 0
End If
End Sub
End Sub
End Sub
Dim temp As String
Dim ind As Integer
If temp = "on" Then
ind = 0
ind = 1
End If
End Sub
End Sub
The VB Str() function pads the number with a space, so you might want to use
this construct instead:
Trim(Str(myNumber))
Right now your PBASIC program is receiving the space pad created by Str().
On your PBASIC side, you might consider doing this:
SERIN sPin, sBaud, [noparse][[/noparse]DEC myNumber]
This would actually eliminate the need for Trim(), and you'll have to change
your code a bit to look for values instead of characters
One final note: The new compiler is available in Beta and has control
structures similar to those found if VB. If you switch, you'll have to
rename your "On" label since that is a keyword in PBASIC 2.5. If you change,
and use my suggestions, your program would look like this:
Main:
DO
SERIN pin, baud, [noparse][[/noparse]DEC dataIn]
IF (dataIn = 1) THEN
HIGH 0
ELSE
LOW 0
ENDIF
LOOP
Actually, this version will receive characters and do what you want. Your
version, should a valid command come in, will hang on that command forever
because your code goes into an infinite local loop -- your program might turn
the pin on or off, but never go anywhere after.
-- Jon Williams
-- Parallax
In a message dated 4/9/2003 12:03:13 AM Central Standard Time,
jagal1979@y... writes:
> Folks,
> Thanks
devices in a room(ON/OFF)
and the problem i'm having is sending a string from the application and receive
with the basic stamp: what am i exactly sending and what am i exactly receiving?
anyway, some of the guys provided a solution that i'm gonna look at later on
today.hopefully it will do it.
regards,
mohammad
Do you Yahoo!?
Yahoo! Tax Center - File online, calculators, forms, and more
usually use a mini-DAQ board that plugs into the back of my computer
(printer port).
