Has anyone used the tokenizer with Dephi?
Archiver
I'm using an ancient Delphi 2.0, and have gotten the Version and
TestRecAlignment functions to work, but I'm still stymied by the
Compile function.
Following the instructions in the "Using the PBASIC Tokenizer
Library" PDF file, I verified, via the TestRecAlignment function,
that my data structiure is aligned correctly.
The error I get is: Access violation at address 10001A61. Write of
address 00000005.
Here's my code:
const
EEPROMSize = 2048;
type
PModuleRec = ^TModuleRec;
TModuleRec = record
Succeeded : Boolean; (*Pass or failed on
compile*)
Error : PChar; (*Error message if
failed*)
DebugFlag : Boolean; (*Indicates there's
debug data*)
TargetModule : Byte; (*BASIC Stamp Module
to compile for. 0=None, 1=BS1, 2=BS2, 3=BS2e, 4=BS2sx, 5=BS2p,
6=BS2pe*)
TargetStart : Integer; (*Beginning of $STAMP
directive target, in source*)
ProjectFiles : array [noparse][[/noparse]1..7] of PChar; (*Paths and names of
related project files, if any*)
ProjectFilesStart : array [noparse][[/noparse]1..7] of Integer;(*Beginning of
project file name in source*)
Port : PChar; (*COM port to
download to*)
PortStart : Integer; (*Beginning of port
name in source*)
SourceSize : Integer; (*Enter actual source
code length here*)
ErrorStart : Integer; (*Beginning of error
in source*)
ErrorLength : Integer; (*Number of bytes in
error selection*)
EEPROM : array [noparse][[/noparse]1..EEPROMSize] of byte; (*Tokenized data if
compile worked*)
EEPROMFlags : array [noparse][[/noparse]1..EEPROMSize] of byte;(*EEPROM flags, bit
7: 0=unused, 1=used*)
(*bits 0..6: 0=empty, 1=undef data,
2=def data, 3=program*)
VarCounts : array [noparse][[/noparse]1..4] of byte; (*# of.. [noparse][[/noparse]0]=bits, [noparse][[/noparse]1]
=nibbles, [noparse][[/noparse]2]=bytes, [noparse][[/noparse]3]=words*)
PacketCount : Byte; (*# of packets*)
PacketBuffer : array [noparse][[/noparse]1..2304] of byte; (*packet data*)
end;
var
TokenizerTestForm: TTokenizerTestForm;
TokenizerVersion : Integer;
function Version: Integer pascal; external 'tokenizer.dll';
function TestRecAlignment(Rec : TModuleRec) : Boolean pascal;
function Compile(Rec : TModuleRec;
Src : PChar;
DirectivesOnly : Boolean;
ParseStampDirective : Boolean) : Boolean pascal;
var
TestRec : TModuleRec;
procedure TTokenizerTestForm.FormCreate(Sender: TObject);
var
SrcBuf : PChar;
begin
TokenizerVersion := Version();
Label1.Caption := Concat(Label1.Caption, Format('%4.2f',
[noparse][[/noparse]TokenizerVersion/100]));
if not TestRecAlignment(TestRec) then
ShowMessage('TestRecAlignment failed!')
else
ShowMessage('TestRecAlignment worked!');
SrcBuf := StrNew('''{$Stamp BS2} ''test'#$0D#$0A'debug
HI!'#$0D#$0A'outs=65535'#0);
ShowMessage(SrcBuf);
TestRec.SourceSize := StrLen(SrcBuf);
if not Compile(TestRec, SrcBuf, True, True) then // <---The error
occurs here.
ShowMessage('Compile failed!');
end;
end.
Compile function.
address 00000005.
Here's my code:
const
EEPROMSize = 2048;
type
TModuleRec = record
compile*)
failed*)
debug data*)
6=BS2pe*)
download to*)
name in source*)
code length here*)
in source*)
error selection*)
compile worked*)
end;
var
Src : PChar;
var
var
SrcBuf : PChar;
begin
else
occurs here.
end;
end.
directive when declaring the Compile() external function. (I had
originally used it because that was the only way was I was able to
get the TestRecAlignment function to work.)
It turns out that STDCALL is the correct directive to use. When I
originally tried it with TestRecAlignment, it failed because the
entire TModuleRec was being passed on the stack. (With the Pascal
calling convention, only a pointer is passed.)
But the Compile() failed with the PASCAL directive because with
Pascal calling convention, the parameters are pushed on the stack in
order from left to right (instead of right to left as with STDCALL,)
so tokenize.dll was trying to use the value of the
ParseStampDirective Boolean as a pointer!
So now I've gotten it to compile a simple program, but I have now
discovered that it doesn't recognize the $PBasic directive! Does
anyone know when Parallax will be releasing a PBASIC 2.5 version?
Greg Ross
> Compile function.
> address 00000005.
> Here's my code:
> const
> EEPROMSize = 2048;
> type
> TModuleRec = record
compile*)
failed*)
debug data*)
6=BS2pe*)
download to*)
name in source*)
code length here*)
in source*)
error selection*)
compile worked*)
packets*)
> end;
> var
> Src : PChar;
> var
> var
> SrcBuf : PChar;
> begin
> else
occurs here.
> end;
> end.
for 3rd party developers.
-- Jon Williams
-- Parallax
In a message dated 4/17/2003 8:52:19 PM Central Standard Time,
GWR@P... writes:
material on a piece of transparency? (I'm using a charge-transfer panel to
do inductive switches...) I thought that one might be able to use that
laser toner stuff that you could apply metallic foil to, but maybe there's
a better / more "professional" way of doing it.
Suggestions? Failing that, where I can get a really thin PCB... I suppose
the other way to do is to "draw" it on with one of those metallic pens (I
know this comes up fairly frequently, but what's a good source of
conductive pens?)
Sean T. Lamont, Chief Mad Scientist |-- lamont@a...
Zen Chemical Productions |-- http://www.zenchemical.com
Fabricators of Unnecessary Amazement
use some sort of plating bath to coat it with a metal film? If the toner is
conductive you should be able to electroplate it.
> This is slightly off-topic, but does anyone know how to print a conductive
> conductive pens?)
Greg Ross
Sent: Thursday, April 17, 2003 7:44 PM
Subject: Re: [noparse][[/noparse]basicstamps] Re: Has anyone used the tokenizer with Dephi?
> When our new compiler is fully released we will release an updated
tokenizer
> -- Jon Williams
> -- Parallax
